Disconnect the Laptop from Power, remove the battery, Hold the power button for 6-10 seconds.
Restart the machine by connecting the power and battery, Hit the Esc key while windows is loading
When your computer starts, meaning as soon as you have pushed the power button
keep pressing the F8 button located on top of your keyboard
press F8 repeatedly till you see a screen asking you the way in which you want to start your computer
in that screen dont select the hibernated mode, just start windows normally
SOURCE: Vista boots to blank screen. Mouse pointer moves. Nothing else
graphic card issue. very bad, very expensive to repair most likely a new motherboard.
SOURCE: Preparing to hibernate
Hold down the power button until the computer shuts off completely. That should solve your problem.
SOURCE: compaq presario C300 stuck in hibernate mode
Try unplugging from the a/c adaptor, and removing the battery for a couple of minutes. Replace the battery and turn the computer on. It should be fixed now.
SOURCE: My hp 530 laptop with windows vista doesn't sleep or hibernate
Sleep/hibernate is a function of the video driver. so download and install the latest video driver from hp.com
SOURCE: Compaq presario V2000
Try booting into the BIOS Screen and resetting to factory defaults. If that fails suggest swapping the hard drive out and re-install the Operating System - Save your old data and migrate the data off the old drive. You can buy an external drive adapter to connect the harddrive to a USB port to migrate you data.
Good Luck!
Testimonial: "Excellent answer ! Very helpful, very fast ! Thanks so much."
