i turn camera on and it has a long shrill beep, then it says "clean the contact area of the card with a dry cloth" below this is has two options, "clean card" or "format". i have cleaned the card but do not want to format as some of the photo's are only on the camera, what can i do?
I had the same problem and resolved it using the following program, which you can download from softonic ( is free ) :
http://pc-inspector-smart-recovery.softonic.com/
Is
easy to use, you connect your card to de pc (with a pc reader or the
camera ), select the card's folder,the file type (jpg) and destination
folder for recovering the pictures and finally press init. After that
the program will detect that the card is broken and will ask you to do
an intensive inspection, answer yes and you'll begin to see your
pictures into the destination folder. The process take a time, but is
satisfactory.
There is more programs to do his as "card recovery", but no free
try to use a card reader and download all the pictures from the card into a pc...its possible that the card will work into a card reader cause those aren't that sensitive ...after that just format the card in fat ...better try to format it again into the camera if it has the feature...and it probably work...but remember ...download using a card reader...if you do not have one ...ask a friend ..there are a lot of computers that have one installed already ...and there are cheap usb ones too ..EX ; http://www.supermediastore.com/cardreader.html
MY 1050sw takes very exposed pictures in direct sunlight. I've had this camera before, but this one...
(More)
MY 1050sw takes very exposed pictures in direct sunlight. I've had this camera before, but this one keeps taking photos that look as if the white balance is off and photos are WAY too over exposed! i see ''white sun waves'' in all my out door photos! tried all settings and even formated camera :(
I took my Olympus 1050sw 'underwater' camera in the sea, then after about 10 mins (at depths no more...
(More)
I took my Olympus 1050sw 'underwater' camera in the sea, then after about 10 mins (at depths no more than 0.5 metres, it flashed up with "battery cover open" then it worked on and off for about 10 mins, and died. Now the red light will flash for a bit when i turn the power on and that's it, nothing else - nothing on screen. Is there anything I can do? Please help!
When I turn the camera on it will make a very loud beep 4 times the screen will flash and then the...
(More)
When I turn the camera on it will make a very loud beep 4 times the screen will flash and then the camera turns itself off
Why is there a write-protect when my microSD and my other memory card doesn't have a switch, either...
(More)
Why is there a write-protect when my microSD and my other memory card doesn't have a switch, either in both sides?
