Question about Garden
Recoil was trying to crank and rope didn't go back in so we took apart and having a problem rewinding the spring. is there a trick to rewinding?
  • 472 Answers
YOU MAY NEED A NEW SPRING FOR THAT
Posted on Sep 30, 2009
My weedeater pull rope won't retract back inside when pulled to start, how do I fix this?
Spring is likely sprung out of the recoil. Take the recoil apart, rewind the cord and turn it enough to put some tension on it. Then put the cover back on.
Oct 04, 2014 | Troy Garden
The rope broke when I tried to start the chainsaw. How do I replace it?
Your rewind spring is now sprung. Remove recoil assy ( the part your rope slides into). Remove all old rope remnants and rewind the spring. Install new rope, tie it off and slowly release spring rewinding the rope.
Mar 14, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Recoil starter assembly
If you can post the engine make, model and serial number I can get a diagram for you. They are usually stamped in the engine housing. Start by removing bolts to remove cover and check spring. If spring is good you should be able to rewind. You will need to cut rope by handle and pull rope up between spindle and inner housing, rewind rope in direction of pull. Let it rewind while holding tip of rope. When satisfied with tension, push end of rope back through hole in cover and reattach handle. This can be tricky. I am thinking of posting a video of this procedure. Let me know if you have more question's.Good luck.
Dec 03, 2013 | Ariens Garden
Husky power washer 2600 Tried fixing starter
I'll send you a link to a great video of how to recoil a starter spring, so you wont lose and fingers or eyes. :)
Aug 01, 2013 | Garden
HOW DO I GET TENSION BACK ON THE STARTER ROPE?
Try giving a few light tuggs and hopefully the spring will recoil itself. If not, you probably spung the spring and you will need to take apart the recoil assembly to get it working again. BE CAREFUL, springs have a tendancy to just 'jump' out and completely uncoil themselves and then you will have a headache for sure. Also, try reaching under the deck (hopefully the motor isn't running :P ) and turn it counter clockwise while someome one tugs at the rope. Many times it will engage itself and rewind just fine. Let me know what happens
Sep 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Handle came off starter rope and rope rewound on spool. Took off power boom and took out tork screws and loosened cover from engine, but there is a metal disc, looks like a clutch cover on the end of the...
You shouldn't have to remove it. Just wide the disk up again to get tension on the recoil spring (lots of tension... enough to pull the rope all the way back in). poke the rope back out the hole ( the hardest part of the job) and put the handle back on. You should be back in action
Aug 20, 2009 | Ryobi Garden
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Mar 12, 2009 | Garden
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
