Question about Sony RDR-VX525 DVD Recorder/VCR
How do I record from the tv - Sony RDR-VX525 DVD Recorder/VCR
Sony KDL 32W705B PLUS A CASSETTE RECORDER RDR-VX 420
Evidently you are recording from the TV. You're running the signal to the TV then out of the TV to the recorder. You should run the signal to the recorder then output to the TV.
May 15, 2015 | Sony Televison & Video
Tip
How to record a program you are watching on your cable satellite receiver.
Hello,<br /><br />Most of the time we watch TV programs with our cable satellite receiver/decoder. And sometimes we would love to record these programs so that we can watch them again. You can learn how to record your TV program while you watching a TV program. <br /><br />All you will be needing is a DVD recorder or VCR (Video cassette Recorder). It all depends on the one you prefer.<br /><br />There are two methods of doing this connection. 1. is RF connection and the other is RCA. But I will start with the RF connection method;<br /><br />This is how is works. Get a RF cord, check the back of your TV, you would see RF in, connect the RF into TV in, then connect the other part to RF Out at the back of the Cassette or DVD Recorder.<br /><br />Turn the Cassette or DVD Recorder and the TV on. Go to Channel 1 or any channel on the TV, search the TV stations automatically or manually in order to get a display of the Cassette or DVD Recorder on the TV. To easily get the Cassette or DVD Recorder's station, play a movie on the Cassette or DVD Recorder while you search for the station. Once you see the display of the movie on your TV, you would easily know that that's the Cassette or DVD Recorder station. <br /><br />Once you have gotten a display from the Cassette or DVD Recorder, save the channel on the TV.<br /><br />Then get another RF cord, connect it to "RF out" at the back of the Satellite/cable decoder/receiver and the other part to "RF in" at the back of the Cassette or DVD Recorder.<br /><br />Now with the Satellite/cable decoder/receiver turned on and the Cassette or DVD Recorder also turned on, press the Cassette or DVD Recorder's channel, you should find search. Scan for channel/stations on the Cassette or DVD Recorder just like you did on the TV and you will find a display of the Satellite/cable decoder/receiver showing on the TV via the Cassette or DVD Recorder. Note that on some Cassette or DVD Recorder, you will have to select "Source" to RF before you can get a display of the channel.<br /><br />Now since the Satellite/cable decoder/receiver program is now showing via the Satellite/cable decoder/receiver, insert a black disc or cassette into the Recoder and press record. The Satellite/cable decoder/receiver programs showing on the TV via the player will be recorded and that would be all.<br /><br />For some recorders that has internal hard drive, you can just press record without inserting a blank disc......<br /><br />USING RCA CONNECTION METHOD.<br /><br />You could also achieve this by using a RCA (yellow, red and white cord).<br /><br />The connection procedure is the same with the RF explained above.<br /><br />Connect the Recorder to the TV. That is, from "Video and audio Out" of the recorder to "video and audio in" of the TV accordingly. Press AV or source on the TV to confirm that there is a display from the recorder on the TV.<br /><br />Now connect the RCA cord to "OUT" from the Satellite/cable decoder/receiver to "IN" at the back of the Recorder.<br /><br />Then, press source on the recorder to "INPUT" (RCA) and the Satellite/cable decoder/receiver's program will automatically display on the TV. <br /><br />While the Program is being displayed on the TV via the recoder, insert a blank disc and press record on the player and it will automatically start recording. You will see the record or record symbol while the recoding is in progress.<br /><br />I hope you understand the above. Please follow steps closely and you won't have any problems.<br /><br />Good luck.
on Mar 09, 2011 | Televison & Video
I have just bought a Digihome pvr320sd tv recorder with freeview, can i set it up as a tv recorder only without the freeview as i already have built in freeview on my tv.
When you set up the recorder Freeview stations will be stored. This means that you can record TV stations without watching them. So you can say watch BBC1 on your TV and record a program on Channel Four. You need the recorder set up with Freeview to recorder channels. Otherwise you would have to have your TV on and recorder set to record via the scart lead. Which would be not great quality and messy.
You should be able to loop the aerial lead so that both the TV and recorder can get the signals from your aerial, if that's what is bothering you.
Dec 22, 2012 | Televison & Video
Can you record a program and watch live TV at the same time?
If you have a dual receiver, you can record to TV 2 and watch any program on TV 1. If you have 2 recordings taking place at the same time, you can only watch what is being recorded.
With a dual receiver, you can place the receiver in single mode and watch a different program even if 2 recording are taking place. In single mode both TV 1 and TV 2 will be watching the same program.
A solo DVR you can record to tuner 2 and watch what you want on TV 1. With the VIP 622 receiver, you have the Record Plus option, you can have all recording go to TV 2. If 2 recordings take place, then TV 1 and TV 2 are used.
Jun 29, 2011 | DISH Network ViP622 DVR DTV Receiver /...
I can't record normal tv progrma from HD tv
My dear friend where you connect the antenna source to the dvd or to the vcr or tv because ,if you wanna record anything you need to connect the antenna source to the dvd and put the channel you wanna record on him
Jul 25, 2009 | Televison & Video
Dvd recorder does not have tv tuner
sure you can record from your TV. You need to connect the AV1 of the tv to the AV1 of the DVD recorder. Then, when the TV is running, you can simultaneously record on your DVD recorder.
Use a SCART cable for the connection.
Jan 05, 2009 | Samsung DVD-V4600 DVD Player/VCR
How to record a running program from TV to DVD
RUN ANT,CABLE INTO DVD RECORDER THEN RUN A CABLE IN TO THE TV FROM THE OUTPUT OF THE DVD RECORDER YOU MUST HAVE TV ON CHANNEL THREE TO WATCH AND RECORD AT SAME TIME ,SET CHANNEL TO 3 ON DVD RECORDER OR INPUT SELECT CHANNEL YOU WANT TO RECORD AND PUSH RECORD WHEN READY
Dec 07, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Nov 20, 2008 | RCA RTD155 System
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Sep 27, 2008 | Televison & Video
Recorder problem
panero,
it sounds like your setup is incorrect. You need to stick the antenna cable into the dvdrecorder so it can get a tv signal then the from tv recorder back out to your tv via your tv modulator. What this means is that you will need to tune your tv to a particular channel ie. channel 3 is the common one to use then change your tv channels via your dvd recorder so it record and if your dvd recorder will passthrough the signals you can probably wtach tv on one channel and then record on a different one.
good luck.
smeags.
Jan 04, 2008 | Cyberhome DVD Recorder - DVR1600
Sony RDR-VX525 DVD Recorder/VCR Logo
41 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
