Where is the filter on the front load machines?
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Depends on the make and model try bottom right , if its hotpoint its in sump hose
Posted on Sep 29, 2009
A light came on to clean the washer. Is there something special I need to do?
Even a blonde can do it! Quick fix/repair for Kenmore He2 ...
? 4:57
https://www.youtube.com/watch?v=4o9hWHQkOMM
Sep 1, 2013 - Uploaded by And Justice For All
Quick fix/repair for Kenmore He2 front loading washing machine... a Kenmore He2 front loading washing machine when blinkinglights error code occurs ... How to Clean Front Load WasherDrain Filter and Empty the Water ...
Front Load Washer Pump Clean Out - YouTube
? 3:03
https://www.youtube.com/watch?v=f9uS8_0-pWY
Sep 6, 2012 - Uploaded by GE Appliances
If you have a front load washer with a pump filter, your pump filter may become ... pressed start again but it still stops and the cleanpump light still comes back on. .... Samsung Washing Machine cleaning the pump & coin trap
Nov 29, 2015 | Kenmore Washing Machines
Clean filter
THERE SHOULD BE A SMALL DOOR ON FRONT LOWER FRONT OF MACHINE OPEN DOOR AND FILTER IS RIGHT THERE!!!! IF NOT IN FRONT CHECK ALL SIDES..
May 26, 2013 | Hotpoint WMA32 Front Load Washer
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Where is the debris filter on a Samsung WF316las/xaa?
There is no more filters to be cleaned on front load machines. It's a self cleaning filter and everything goes through the drain.
Mar 14, 2011 | Samsung WF337AA Front Load Washer
The front Load machine does not spin the excess water fron the wash on the final rinse. If I set the spin cycle again, it works ?
Most all front load machines have a pump filter. If the bottom front panel is removable, remove and unscrew filter. Clean filter
Nov 07, 2009 | GE Washing Machines
Locating the filter
based on info provided your ge would be a frigidaire made machine, only filter is at drain pump. to access remove lower front access panel (screws on bottom) pump sits in middle of machine, locate large rubber hose connecting to tub, loosen clamp and pull off. inside is plastic strainer cup, empty and replace. make sure nothing went past to pump, reassemble.
Jul 19, 2009 | GE WSXH208A Front Load Washer
Where is the drain filter and the spin rinse sensor located on
Have not heard of a part called a "spin rinse sensor". Drain filter is located behind the small access door at the bottom left on front of the machine. Use small hose there to drain remaining water out of pump and hoses, then unscrew the big thing on the right side (end of the filter).
Mar 14, 2009 | LG WM1814CW Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
