Question about HP Pavilion dv7-1132nr Notebook PC
HP Pavilion overheats and Turns off by itself
My HP Pavilion overheats and just turns off. Call HP and they said replace the battery which didn't work. Any help would be greatly appreciated. Thanks.
  • 40 Answers
Clean the fan unit out with compressed air from the under side..
does the fan operate at full speed when you first turn on the notebook???
you should hear it at first boot.... full speed
do not hear it.. then your fan is out...
you can get a fan booster that clips on to the back of the computer and attaches to the usb port for power
get back with me if these solutions do need work
Posted on Sep 30, 2009
  • 68 Answers
Over heating is not a battery related issue
but a cpu related one
what happens in a computer is that the cpu is attached to a heat sink that takes heat from the cpu
and a fan is attached to the heat sink that blows the heat away
now between the cpu and the heat sink there is a special paste called thermal paste/grease which allows the heat sink to take the heat from the cpu
after a period of time ranging from 6 months to 3 years this thermal paste gets consumed because of the heat
so now you have to reapply that paste
many companies offer a wide range to thermal pastes, some of them are coolermaster, sunbeamtech, arctic-cooling
the other possible reason could be that the hot air blown from the air is not able to come out and is getting trapped because of dirt stuck in the filter of the area the fan is placed.
but most probably its the thermal paste problem
Posted on Sep 29, 2009
  • 47 Answers
Try a cooling station.
Laptop turns off when optical drive start to work
i will start with a battery test looks like the motor is drawing too much current for ac support only .
Jul 13, 2013 | Pavilion HP Pavilion DV4-1225dx AC Adapter...
Hp laptop goes on hp sign comes up then the whole thing turns off why
MAY BE OVERHEAT OR U NEED TO CHANGE YOUR MEMORY RAM. TRY REMOVE ONE OF YOUR MEMORY RAM AND TURNS IT ON
Nov 25, 2010 | HP Pavilion dv5-1000us Notebook PC
HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook: My Hp laptop turned off by itself and wont turn on...
Make sure your Notebook is not overheat if it is then you have to make sure the fan is working and have to work on the NB by placing it on a hard surface and also BIOS update will also help to resolve the issue.
if in case the notebook is not overheating boot to BIOS screen and check if the Notebook turns off by itself in bios if it does then its a hardware issue and you need to contact manufacturer to service the notebook
May 18, 2010 | HP Pavilion dv9000z Notebook
My HP dv6700 sometimes turns on and off by itself
What you're describing sounds like a hardware problem, not a software one, if the resetting occurs long before Windows loads.
As it's a notebook, my first suggestion would be to
make sure there's nothing wrong with the power point you're running it from, or the power cable. If you plug a desklamp into the same circuit (old-style incandescent globe, not fluoro) does it flicker? Is the power cable firmly plugged in? Has it been chewed by a pet?
Next run it without the battery and see if it still plays up. If it does still misbehave, you have a problem in the power adaptor or the internal circuitry of the notebook. If it works without the battery, the battery is on the way out and should be replaced.
Apr 11, 2010 | HP Pavilion DV6700T Notebook
Intermittant sound on my HP Pavilion dv6-1340
You need to update the sound drivers.
If it doesnt work out than contact ur manufacturer it seems hardware
Feb 05, 2010 | HP Pavilion dv6000z Notebook
Laptop hp pavillion dv7 turns off by itself when battery is in and it is plugged in Problem
Update the BIOS and check if doesnt work, try running a recovery on the sys.
If problem still persist than contact manufacturer as the sys has to be repaired
Jan 21, 2010 | HP Pavilion dv7-1132nr Notebook PC
My DV9000 shuts off by itself, randomly.. I know the motherboard gets hot so I'm not sure if it's the heat or I need to replace something..I've had my laptop for a few years now..Has anyone experienced...
I have distanced myself from HP computer products; too many problems in recent years. You may have an extended warranty; check through these to see if you can expect to get help from HP:
HP DV9000 series recalls
Jan 02, 2010 | HP Pavilion dv9000z Notebook
It switches off itself
Take out the battery and only try the ac adaptor. If the system still turns on then off then take out the hard drive and dvd-drive. If it still turns on then off then your motherboard is bad and would need to be replaced.
Apr 04, 2009 | HP Pavilion DV6500Z Notebook
HP Pavilion dv7-1132nr Notebook PC Logo
1,112 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
