Question about Honda Water Pump Honda Engine
THIS PUMP HAS WATER IN THE SIGHT GLASS - Honda Water Pump Honda Engine
How does the water flow through the sight glass? How do I know if my pool is filtering
water only goes through sight glass when backwashing check your chemicals make sure ph and alkalinity are within spec also check chlorine total and available sounds like you need to super shock pool
Jul 24, 2014 | Hayward Pro Series 18" Above Ground Pool...
Oil seeping from Comet BXD 2525 pump
out the drain plug ? Sight glass window ? Under the pump where the crankcase meets the pump head?
tighten plug, replace oring on sight glass or replace low pressure seals if near the pump
Dec 09, 2013 | Comet BXD 2525 G Pressure Washer Pump
I have a hayward s166t filter, guage reads 0 and sight glass water does not swirl when backwashed
Does it show pressure when in "Filter" mode?
If not, then your pump is either not primed, Impeller is plugged, or there is not enough water in the pool, you are sucking air.
Jul 18, 2013 | Hayward S166T Pool Filter System w1 HP...
How much oil does the Anrovi. RkV 4g36 take
rkv pump half of sight glass on back cover any excess can cause over flow if back cover has no sight glass then you will have to use the dipstick do as follow fill pump crankcase while inserting the dipstick til it stops without screwing it in then remove the dipstick and place the end to the pump casing if you see oil your okay cause by the time you fully insert the stick its gonna show where it should be and again half the sight glass:):)best oil to use is 30w non-detergent oil
Jun 18, 2013 | Honda Pressure Washer PSI 3000
My sight glass has NO water in it, is this normal? it used to have water in it, the pump works fine as water is circulating. any ideas?
The sight glass is used during the backwash process. When you back wash your pool filter it will fill with dirty water. As you progress the water will become clearer. Once the water is clear your backwash is complete.
There may be some residual water that remains however that is the process.
Rod
US Parts Center
888-521-6183
Feb 12, 2013 | Pool & Spa
What oil to use in the power washer water pump
Oil used in engine is SAE30, I would suggest adding bit of Nulon or similiar Teflon based before even first run as it will extend life of the engine, This is air cooled Honda and therefore overheat easy.
Oil used in pump is Universal Tractor Transmission Oil.
Except two, all pumps are equiped with sight glass, fill as indicated on sight glass or dipstick.
To extend life of your equipment, change oil in both, engine and pump after 50hrs.
If you live in colder climates, where freezing is possible, do not forget to drain pump and high pressure hose from water to avoid winter damage.
Hope this will help keep your equipment in top notch for years to come:-)
Jun 22, 2010 | Northstar Pressure Washer 3000 PSI
I have a NorthStar M157471A. What weight oil goes in the pump?
I just answered that question on another thread... will repeat:
Jul 11, 2010 | Northstar Pressure Washer 3000 PSI
Older Faema double head. Power light on, but
It is on the right side of the machine behind the grouphead if you remove the top panel you will see te box with the red switch sticking out. MAKE SURE THERE IS WATER IN THE MACHINE FIRST!!!!!! Do not trust the sight glass, if the level probe is in there, turn machine to 1 then disconnect the electrical connector on the side of the sight glass, the pump should kick in and water will flow in the boiler, if the level does not increase in the glass, then the machine turned itself off because the element got too hot from lack of water. The hole for the sight glass is blocked.
Jul 31, 2009 | Coffee Makers & Espresso Machines
Adding pressure gauge to Pavoni Europiccola
  1. in the boiler water is heated and presured up to 1.5 bar
  2. when water gets in lever and non return valve closes becouse you press the lever down, your energy is used to get high pressure, it should be frpm 7 up to 9 bar.
  3. SOLUTION==if you search way for modifying, you must consider that you must pump directly to group, not to boiler. in this case water will be cold (becouse comes from pump). you will need boiler in boiler to heat the water wich comes from pump before it gets to group. this is bit more complicated than you thought may bee but it is only solution.
Feb 20, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Honda Water Pump Honda Engine Logo
44 people viewed this question
Top Honda Tools & Hardware - Others Experts
John Loiselle
Level 1 Expert
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Honda Tool and Hardware - Other Expert? Answer questions, earn points and help others
