Question about Refrigerators
Refrigerator Water Hose
Can someone recommend a good refrigerator water hose that will not give my water and ice a bad taste? I have tried one from Whirlpool (7' Industrial Grade Refrigerator Water Hose, Part #8212490RC) and one from FlowMaster (5’ Length Lead Free Flexible PVC Water Line, #IPN05). My wife says both cause the water to taste bad.
I do not want to use the ¼” copper or plastic tubing hook-up method. I have searched forums and found conflicting recommendations on milky white colored polyethylene, clear, stainless steel, neoprene rubber, clear plastic, braided small rigid plastic.
My source water supply tastes fine.
Please help. Lenny
  • lenjen Oct 01, 2009
    Interesting observation, maybe so.
  • Terrie Thiessen
    Terrie Thiessen May 11, 2010
    If you've tried changing out the tubing several times and find that the water/ice still has a funny taste then perhaps it is the refrigerant and not the tubing.
    Personally I find that all water/ice that comes out of fridges tastes funny.
    Sergeant:
    Champion:
  • 323 Answers
Copper is best with compression fittings, just install an in line filter
Posted on Oct 24, 2009
Bad fan blower smell and bad smelling and tasting ice cubes from ice cube maker
If unit has a water dispenser, how does water taste? I've run across bell peppers that will emit a bad smell. Keep in mind 95% of all refrigerators circulate air from freezer to refrigerator side and then back. It continues to circulate air so bad produce from refrigerator side will get into freezer side and ice will absorb smell. First, dump all ice. Then line shelves in refrigerator side with newspaper, that absorb smells. You can even try kitty litter in small cups in refrigerator side. Bell peppers gives off that metallic smell and can take some time to get out of unit. Highly unlikely a motor is bad and you've already changed outside water line.
Aug 07, 2015 | Maytag Refrigerators
Our Sub-Zero Mdl 680F is 11 years old, and virtually for its entire existence in our house, the water and ice dispenser has been un-useable because they taste bad. The taste was "oily" almost as...
Hello
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Replace the water filter cartridge in your refrigerator if the ice tastes bad or the control center display recommends it.
Sep 07, 2011 | Sub-Zero 680 / F
I have tryed everything possible to get the taste out of my ice and water in my new Whirlpool indoor water and ice system is it possible to bypass my water resvior in my refrigerator and go directly to my...
if there is just one inlet and one outlet on the reservoir you should be able to put a small copper tube between the two ends and hose clamp them, there should be no worry of a leak since there should be no pressure in this hose except very low and only while the icemaker is calling for water, however i dont think it will solve the taste problem to bypass the tank, it may be that the plasic is new and you are getting the taste of the plastic?
Aug 24, 2011 | Kenmore Side by Side Refrigerator
The water and ice taste bad. The filter is new
put a box or two arm in hammer baking soda in freezer water and ice tends to absorb different orders give it a few days should be ok good luck zap
Apr 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
There is a bad order coming from ice and water dispenser. I changed the filter but it didn't help. Smells like ''dirt''. Thanks, Linda
Replace water supply line with the plastic tubing ice maker line. It fixed mine that had a metal braided line on it that made the water taste kie rubber and dirt,, after that I tried a vinyl braided line.and it made the water taste like garden hose water.. The plastic tubing was the cure. Reply and tell me what you have.
Mar 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water has a bad taste
try replacing the filter in the fridge you will have to order it from whirlpool or your local appliance store
Jun 29, 2009 | Whirlpool ED2FHEXN Side by Side...
Bad tasting ice
disconnected your water line to your fridge and let it rum in to a bucket so you will have fresh water for your fridge but before plug it back to your fridge pour a example in to a cup and drink it to see how it theist like. if that don,t solve your problem, there is a way to get rid of bad rubber taste on the water , but is kind of hard to do first you need to take you refrigerator out side because is going to be messy find some kind of water pump and a bucket and some hose. disconnect the water line going out of the water valve to your ice make and rig your hose together whit that one. on the bucket pour a full bottle of Synthetic vinegar "yes the same stuff you put in your salt", make sure is synthetic not the natural kind using a pump flush your refrigerator whit the vinegar, you can add some water if you need if there is two water valves do the same on both. good luck.
Jun 12, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Bad tasting water and ice from fridge and kitchen tap...
Hi!! change your copper line going to the icemaker and also install a water line filter you can buy one at homedepot easy to install and has instructions on how to...good luck..
Jan 05, 2009 | U-Line BI-95
ADMIRAL FRIDGE MODEL AS22N8DE WATER AND ICE TASTE BAD
change water line into refrigerator Alge will start to grow, also flush line into refrigeratorwith a little bleach to kill any alge in the line. It will take a while to get bleach
Sep 26, 2008 | Refrigerators
Very bad tasting/smelling water and ice cubes - Superba KSRS27QAAL05
Since I found that the water itself being fed to the trays and being dispensed was bad. I replace the nylon, reinforced plastice icemaker hose with 1/4" copper supply line. That, along with purging the hopper (getting rid of) any old ice as well as washing the hopper out real good and giving the freezer a general cleaning - seemed to do the trick. No repugnant odor or taste. (I didn't even replace the filter- the cycle is every 6 mos.)
Hope this helps others who may be experiencing this same prob with this type of side by side appliance.
Lou
Jul 30, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
359 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
