Question about Stanley 46 - 050 10 - 3/4" x 6" Quick Square Adjustable Layout Tool
Not sure how to find actual length of hip rafters from plumb cut at ridge to birdsmouth at wallplate.I have 2 stanley quick squares but have misplaced the little instruction books.I would appreciate your help in this matter. P.S. The same problem exists for valley rafters.
    Scholar:
  • 75 Answers
Use Pythagorus. Measure the horizontal length from the plumb ridge cut to the position where the horizontal birds mouth touches the top plate on the wall closest to the ridge. This point should be 1 1/2" in from the outside edge of the wall. This is your run.
Now measure the vertical height from the top of your wall plate to the where the bottom of your vertical cut from the rafter will end up on your ridge. This is your rise.
A squared plus B squared equals C squared. Get your calculator out, if the run is 12 feet and the rise is 4 feet, then 12 squared (144) + 4 squared (16) equals 160. The square root of 160 is 12.65 ft. or 12 feet 7.79" long. There are other ways, but this is most accurate. Make sure your ridge is parallel to you wall.
Posted on Nov 06, 2009
  • stefanm597 Nov 06, 2009
    Good Morning, I apologize about the post last night. You said hip rafter and I gave info for a common rafter. You described a common rafter from wall plate to ridge face, a hip is used on cottage style roofs and goes from the corner to the ridge, the hip rafters then go from the wall plate to this hip, each one getting shorter.
    You probably don't have your ridge up yet so the previous post won't help. Send me more info or you wall dimensions, which way your rafters are going and the pitch and I can send answers back. If you know how to do CAD drafting you may download for free 2D drafting from Solid Edge Origin and draw it out yourself.
    Please check with your local building code to see about rafter spans and size of birdsmouth which is probably 1 1/2", I make it 1 3/4" to be safe.
How do I determine the length of a rafter from from birdsmouth cut to peak
Using a rafter square determine the pitch of the roof.
Oct 12, 2014 | Garden
What is the length of a rafter on a 6 12 pitch in a 10 spand?
The if the sloped length of the truss rafter is L, the roof span S, the roof angle A, and the overhang V, then the equation for L is
L = V + R/(2cos(A))
The equivalent formula using the pitch, P, is
L = V + (R/2)sqrt(1+P2)
Oct 04, 2014 | Computers & Internet
What do all the numbers on a framing square mean and how do read them?
The numbers on the side of a framing square are used for many things. The small leg allows you to quickly lay out a wall on16" centers. The other rows of numbers help you figure the correct sizes to cut for hip roofs (roofs that have slope on all four sides.)You can get an instruction Manual from Stanley or it may be availabile on the net. Google (framing square instructions)
Aug 05, 2013 | Stanley Homeowner Carpenters Framing...
I am trying to get a 10 degree angle on a 2*4 can you tell me how?
Hook the square on the egde of the 2x4, if you draw a line along the other edge, this should give you a 90 degree cut to the length of the 2x4, if you want 10 degrees less (80) then pivot the square on the edge (length) of the 2x4 until the 10 lines up with the edge that you just pivoted away from. Pivot more and you'll get 20 degrees off of a 90 degree cut (70).
Oct 31, 2009 | ACE Quick Square 10inch
Directions on how to use a square to cut common rafters we have a stanley squ and no manual, on use
A standard square is used primarily for drawing 90 degree angles. Simply hold the fat side of your square firmly against the length of rafter. The skinny side of the square should be lying accross the rafter, forming a 90 degree angle with the side. Use a pencil to draw a line along the edge of the square and use this line as a guide while sawing the rafters.
Sep 27, 2009 | Carpenter Stanley 45-500 Handyman Steel 's...
Need to know how to figure a rafter cut
Assuming you already know the angle you require, take the edge with the level on it(if you have that model) or the side that hangs over and hook it on the edge of the board. If you look at the top, on the 90 degree end, it says "pivot", and that is where you will spin the square around. You read on the 45 degree end that was hooked to the board for you angle. If you are trying to cut a rafter at a specific pitch such as a 6/12 you will spin the square around until the 6 on the Common scale lines up with the edge of the board. The Hip/Val scale is for cutting hips and valleys for the roof structure.
If you have any other questions, feel free to contact me here
Bob
Sep 11, 2009 | Swanson Speedlite Level Square
How to use the stenley roofing sqaure?
take your board make a mark on the side of board put your speed square on that mark(the squared side)flat up agianst the board rotate the square until the 15 deg comes to the other side of board then make your line.
Apr 06, 2009 | Stanley 46 - 050 10 - 3/4" x 6" Quick...
Stanley 46 - 050 10 - 3/4" x 6" Quick Square Adjustable Layout Tool Logo
410 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Steve
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
