Question about Samsung Televison & Video
Red light opens, but screen remains dark, i can hear the start up sound. When i turn tv off, it reopens by itself, unfortunatly with black screen! i have a samsung flat screen tv 30", model code LN328360C, version sg05.
  • I just received a notebook from verizon I try-ed to connect to internet but are unable to connect
Posted on Sep 29, 2009
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Hi. I have a 2004 52' Flat screen projection TV. For the past couple months, we have turned on our TV and all we hear is sound, but no picture comes up. We thought the bulb was having problems. We ordered...
The buzzing is the ballast arc gap,normal sound. When the tv starts does the lamp start to come on. Can you see any light from the back? Sounds like bad ballast. Unfortunatly this part is no longer available. the light engine will have to be removed and sent to Toshiba to be rebuilt.
Nov 26, 2009 | Toshiba 52HM95 52" HDTV Projection...
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Feb 12, 2009 | Hannspree HANNslounge 32 in. LCD HDTV 32
TV power light comes on, but no picture
I have the same problem. I now turn the TV on manually and tilt it forward at the same time. This has been working for about 6 months now. I don't know why tilting it forward gets the picture back but that could be part of the problem going on internally. I cannot afford to get it fixed. The TV is only 2 years old. We thought we were buying a good product. Guess Not. Try this.....
Jan 14, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Screen went dark
can you confirm make and model number please.
Dec 10, 2007 | Mitsubishi WS-55807 TV
Red light stays on
First before a reset the set must turn on, if the set just sits there with the red LED on you have further problems, so does the set display anything?
Oct 08, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
