Question about Microsoft Windows XP Professional for PC
No datas is showing in dc rom
Cd drive is detecting in bios .. in my computer cd drive icon is showing, that icon i can't able to show the data's ....
pls help me how solve that problem
  • 38 Answers
Plz clear data is available in cd , cd is proper write or not
plz sure
Posted on Dec 19, 2007
My Lifebook C2340 won't recognize it's own DVD-ROM. When I set the CD in the BIOS, it goes back to "None". It doesn't show up in My Computer. I've cleaned the contacts and tried another DVD. Still won't...
Does it show the device in the BIOS? If not then there could be a problem with the motherboard hardware. If it is not showing up in the BIOS then I would first verify that the power connector for the drive has voltage. Also verify that the slave/master jumpers are correct if the drive has any. You could also try downloading the BIOS update from Fujitsu and see if after updating the BIOS it brings the cd-rom drive detection back. If the BIOS is seeing the drive but Windows is not then the problem could be with the Windows drivers or installation. You could try going into the control panel for windows and use the "detect new hardware function" and see if Windows detects the drive.
Dec 16, 2009 | Fujitsu LifeBook C2340 Notebook
I had to restore my emachine to factory settings
Open "My Computer".
Insert a "data" CD, and hold the LEFT-SHIFT key down for a minute.
Watch the icon for the CD-drive change from the "standard" icon to something specific to the data CD.
Right-mouse-click on the CD's icon, and choose "Explore",
to open Windows Explorer to view the "data" files on the CD-disk.
Dec 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
Shuttle shut down problem
go to BioS set up..
see to it if the CD Rom Drive has been detected..
if Not,,, try to connect again
...back to BIOS SET up
if it it...
then boot the computer until it pop up the windows environment..
double click "my computer " icon
if CD ROM has there..
your computer normally shut down..
Oct 19, 2009 | Shuttle XPC PC Desktop
I've lost the connection to the E: (CD-Rom) drive to my computer. What needs to be to done to get it back?
go to start>>right click on my computer>>manage>>device manager>>dvd/cd rom drives>>disable and then enable ur driver and u'll get it back
plzzz rate
Oct 15, 2009 | Computers & Internet
1.check your connections of CD Rom inside the Cpu box, if any loose contacts there, then your cd rom wont appears on the computer,
2. change the data cable
3. connect different power socket to the cd rom
4. goto Bios setup, press Del key or F2 key to enter the Bios setup
5. check your cd to detect
6. save it and restart your computer
Jun 22, 2009 | Intel D101GGC Motherboard
Cd rom icon doesent show up
if cd rom does'nt show in windows icon it means that your cd rom is not detected by bios. pls check all cables and power from your cd rom. check also master or slave drive settings.
Jun 07, 2009 | Computers & Internet
My computer does not show my D:/drive, so it does not work
I would assume that your D drive is your CD Rom Drive. If you go into My Computer and the drive isn't there, Lets assume first that there is a problem with the Drive. If you have power to it and the drive does open to let you insert a disk, then our next step is to see if your data cable running to the drive is connected. Make sure that all power cables are unplugged before you open up the computer. Once opened look at the back of the CD Rom drive to check that the power plug is connected. Its the first set of 4 wires closest to you. The next cable next to that is the CD Rom Data IDE Cable. This cable must be plugged in all the way. Most of the IDE Cables will have a red stripe on one side. Make sure this red stripe is closest to the power cable for the drive. This will insure that you have this plugged in correctly. If you follow the IDE cable from the CD Rom to the mainboard (Motherboard) , you can make sure that this end is also seated firmly to the board. If all this is as it should be, go ahead and plug all your cables back in and restart your computer.
If this still doesnt solve your problem you might want to check your bios and insure that the CD Rom is recognized. It will show up in there if it sees it. If any of these solutions dont solve your problem, I would be leaning toward a bad CD Rom Drive.
Joe < Data Miner >
Nov 01, 2008 | Computers & Internet
Dvd-rom icon missing
(1) Check bios for detection if detected continue the following steps else DVD is gone or you can remove test it in other system.
(2) You can manually DVD from control panel by clicking add new hardware wizard, continue the step.
(3) last option try install your operating system agin.
Apr 19, 2008 | Panasonic Matshita- | CW-8124-B | USB 2.0...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
My DVD Rom is not detected by the system
When it comes to installing a new driver you have to make sure is supported by your PC, that said it may be that you need an installation CD, if the driver does not come whit one try to download it from the website of the manufacturer. another solution can be that your driver may be conflicting with another driver, this means that your problem driver needs to be a master or slave check on the installation manual that came with the driver. Try this
Aug 21, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Microsoft Windows XP Professional for PC Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
