Question about Electrical Supplies
Hi, i need to fix a switch to my bathroom mirror. it has been wired but not to external switch. where can i buy this switch or pull cord switch.
  • 302 Answers
Home Depot or any other hardware store would be a good place to start. If you have a Best store in your area that would be another good spot. If they don't carry the switch you need,most places will be happy to point you in the right direction.
I would like to be able to narrow it down for you,but I don't know which city/country you are in.
Posted on Sep 29, 2009
How do i connect a bathroom LED mirror to my house lighting circuit? Can I wire it into a light switch?
I'd suggest that you hire a licensed electrician so that the installation will meet all local codes, and probably will not burn your house down.
Make sure that you know what the voltage requirements of the mirror are
Jun 25, 2014 | Electrical Supplies
Dimplex bathroom fan heater cord problem
take the cover off and clean the inside and were the cord is and use some wd 40 turn of the supply first and that should loosen it for you
Jan 06, 2014 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Switching on
The switch is failing.
Dec 19, 2013 | Heating & Cooling
Hi there just fitted brand new bathroom pull cord.... works but have to pull it three times. Any ideas why ? Thanks Lydia
if the wires are correctly installed, and tight. then you may have a bad pull chain switch. good-day ! but first turn off electric, and see if the wires are not loose and the wire nuts are tight behind light.
Feb 16, 2012 | Duravit Home
Hello, I currently have a celing lamp in my kitchen. There is a little cord you pull to turn it off. The onlything is, is that the cord is not working and i dont know how to turn my lamp off if not to...
The lamp has on-off pull-chain switch.
You can buy replacement pull-chain switch at hardware store.
Buy the pull-chain switch that has two wires.
Buy two yellow or orange wire nuts.
Switch off breaker.
Take apart light.
Remove old pull-chain. Strip back the wires if needed, twist wires together.
Connect new pull-chain switch using wire nuts.
Sep 22, 2011 | Electrical Supplies
Mirror glued to wall
That's actually a pretty common method for professionally installing bathroom mirrors. As you mentioned, tape a star pattern on the mirror and then use a thin piece of piano type wire to slice through the adhesive. Keep the ends of the wire as close to the wall as possible while cutting so that you don't break the mirror. A local glass company can provide the best type of wire for the job as well as tips on the best way to get the job done - particularly if you imply that you'llbe buying your new miror from them. Be sure to wear leather palmed gloves and eye protection when doing this job!
May 31, 2010 | Home
Bathroom fan wiring.
There are two wires in the power cord of your bathroom fan. Buy an electrical plug with a built-in switch. The plug has two terminals in it. Just get the two wires of the bathroom fan to the two terminals of the electrical plug. Secure all bare wires along the line with an electical tape. Get this done, and send us your e-mail it this help you.
Oct 03, 2009 | Electrical Supplies
Pull cord switch
If it is a 1 way switch circuit (2core +earth cable) it should be LIVE/HOT in COM and Aux live (to the light) in L1 . I
f you have a 2 way circuit (3 core + earth cable) the aux strappers go in L1 & L2. and LIVE/HOT to COM
Remember to disconnect the power before working on electric wiring.
Please remember to rate this solution.
Oct 15, 2008 | Electrical Supplies
Electrical Supplies Logo
52 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
