Question about Vivitar ViviCam 5100 Digital Camera
When i turn it on i get nothing i have changed batteries but i am still getting blank no light nothing
Blank screen
  • With the computer on, use a flash light to inspect the screen. If you can see a very faint image then either the inverter board is bad or back light. Usually its the inverter.
  • If you get nothing, plug an external monitor and toggle the display to it. If you get output then your screen is bad or possibly a loose video cable.
  • If you get nothing, power off, pull battery pull all memory out. Power on computer. If you get BIOS and a no memory error, one of your memory modules is bad.
  • Still nothing, then the motherboard is bad.
Jan 29, 2013 | Acer Veriton Z290G 185 320GB
Sanyo dp42848 turns on but blank screen
Replace the Main board if your not hearing any audio from the set.
Oct 27, 2012 | Sanyo DP42848 LCD TV
HI i have a toro DCC control box and after coming back from holiday my sprinklers wouldnt work. I noticed on my Control box that the screen was blank so i changed the 9V battery thinking it was that. the...
Remove the battery. Unplug the timer. Make sure that the front of the timer is properly connected to the internal board. Plug the timer back in. Try to operate the timer using manual watering. The battery is only for backup, don't install it until you get the timer to operate on ac power first.
Jan 03, 2011 | Garden
Hi. My acer aspire 5735 doesnt turn on. I turned the laptop off as normal however when i came to go back on it just wouldnt turn on. The charge light stays on to show whether the battery is being charged....
When a computer does not boot up, but the battery is charging, it could be a CPU or RAM problem.
Re-seat the RAM modules, this will make sure it makes proper connection to the motherboard.
Next try removing the battery and power up the laptop with just the power adapter connected. If it boots up then insert the battery while it is powered up.
Oct 23, 2010 | Acer Aspire 5735 Notebook
Radio wont turn on, no display.
Unhook the battery for 5 mins.
Mar 01, 2009 | 1998 Volvo S70
Orange light on psp
did you try changing the battery and leaving the psp to charge a long time?
Mar 29, 2008 | Sony PlayStation Portable (PSP) Console
Cell phone (Sony Ericsson W910i) turns itself off every 30 seconds
i have one too and it always turns itself off at least 15 times a day and a red light comes on at the back and the screen is blank. It hangs up on people half way through phone calls, and tells me i have messages wich i don't and comes up with blank messages which i can't delete!! Today it has done the exact same thing again but it has been frozen for over 3hours i have tried taking the battery out and nothing works :(
Feb 26, 2008 | Cell Phones
Vivitar ViviCam 5100 Digital Camera Logo
24 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
