Question about Dryers
My dryer squeaks horrible while running. It has broken 2 belts in 3 weeks. What is wrong?
    Genius:
  • 1,461 Answers
Jockey pulleys are faulty you will find squeak alters as drier heats....
Posted on Sep 29, 2009
Very squeeky dryer, starts out quiet then intensifies through the cycle untill it can be heard from outside; has a rhythmic squeek.
The belt is probably rubbed smooth. Since you already sprayed it, after the spray dried out, it starting squeaking again. I suggest examining the belt and replacing it if necessary.
Mar 22, 2016 | Dryers
Squeaking sounds
slipping belt drive on drum , have it checked.
Mar 22, 2014 | LG DLE1101W 7.3 cu. ft. Ultra Large...
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
My crankshaft is very wobbley and make a very high pitched squeak
You need a harmonic balance. Very common problem!
May 21, 2010 | 1995 Geo Prizm
This is an electric dryer. Over the past week when
one of 3 things could be wrong/1)dry,tight motor bearings/2)drum bearing bad/3) bad motor windings,remove belt off drum and see if anything turns hard i.e. motor,drum each one isolated then run motor w/o drum belt on drum and see if motor gets overly warm or hot especially around the bearing ends
Nov 15, 2009 | Kitchen Ranges
2004 ford taurus is running horrible
If you didn't change one spark plug wire at a time then you may have your firing order off...
Please pick your motor...front or rear wheel drive...
3.0L (VIN U) engine Firing order: 1–4–2–5–3–6 Distributorless ignition system
3.0L (VIN S) engine Firing order: 1–4–2–5–3–6 Distributorless ignition system
Oct 11, 2009 | 2004 Ford Taurus
Makes squeaking noise after running for about 10 minutes
Replace the dryer drive belt and the dryer tub rollers.
Mar 01, 2017 | Kenmore Dryers
My dryer is making a horrid noise
belt would squeak. but a horrible noise would probably be coming from the gear box. it may need a simple lubrication to the worst of replacing the whole gear box.
check it underneath the tub. if you can remove the housing and run it while it is open and see or hear where the noise is coming from. be careful on the moving parts once it is running with out a housing.
tnx 4 using fixya,
drcool
Nov 08, 2008 | GE DBSR453EBWW Electric Dryer
Squeak
Pinot, usually the squeak on these 417's is coming from the drum ball and plastic bearing. Sometimes they crack and sometimes just need to be greased. Go to this link http://www3.sears.com/ and enter your model number, upper left hand corner. Follow the link and click on view diagram, page 1. Look at number 12 and 34. This is the drum hitch and plastic bearing. Your husband will have to remove the top and once he has the belt off, pull up on the drum to get it off the bearing, (plastic coupling that the ball sets into. If it's not cracked and the ball is is good shape, just grease it. If it's cracked and the ball is a chewed up, replace them both. This job is done better with 2 people cause it's not the easiest deal. You can find the part numbers on the parts link right next to view diagram. Let the cat know if you need any more help, Catriver.
Jan 06, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
