Question about Microsoft Excel for PC
Moving between cells
When I use the keyboard arrows to move between cells - the focus doesn’t change between the cells but stays on the same one and just moves the whole sheet down. Why?
    Problem Solver:
  • 5 Answers
It is because you probebly clicked on 'Scroll Lock'.
Click it again
Posted on Dec 19, 2007
After restarting my computer the cursor stopped responding to the mouse.
You're probably running Windows, and that's a common problem, and usually very easy to fix. If you are using a wireless mouse, remove the USB receiver, wait 10 - 20 seconds and put it back in. If that doesn't work, remove USB rec. , shut off mouse and go through a restart. Try restarting with them removed, if it doesn't work, try restart with them in and turned on. You can use keyboard commands to do this next part If that doesn't work, go into the Control Panel, system, device manager, mouse, right click ( lined square to right of space bar ) then properties, reset to default - The windows symbol beside space bar is the start menu, the arrows control scrolling through options or moving the page, TAB changes what the computer is focused on, ALT and F4 closes whatever program you're focused on - pressing it twice will cause a restart. And if your comp ever jams up, press CTRL, ALT and DELETE at the same time, opens task manager and unjams,,, usually. Hope some of that helped. Grimm
May 01, 2015 | Computers & Internet
Cursor not moving when using keyboard arrows
they won't move the cursor.
Only the selection.
Nov 22, 2013 | Microsoft Excel for PC
Automaticaaly arrow/ cursor is moving to end , moving down automatically
Mostly caused by a stuck key on the keyboard. Just turn off the system, and tap on all the keys gently to release them - should take care of the issue. You should also check how this works in safe-mode to ensure it's not due a software that was recently installed.
Oct 11, 2013 | Acer NSK8458AN Keyboard
Moving focus
Check the focus selector lock, located just below the multiselector (the cursor pad with the arrows). Make sure it's not in the "L" position, which locks the focus area.
Sep 15, 2012 | Nikon D700 Digital Camera
How do I set the resolution on my Canon SD850?
The instructions for changing the resolution are on page 30 of the manual.
If the pictures are fuzzy, increasing the resolution won't help. The most likely causes of fuzzy pictures are as follows
1) Focus. Check to make sure the focus is on the subject. If something else in the picture is sharp while others are not, then the camera may have focused on the wrong subject.
2) Subject motion. If moving objects are fuzzier than stationary objects then you need to use a faster shutter speed (or flash).
3) Camera motion. Just because the camera is on a tripod doesn't mean it doesn't move. One philosophy says that if a tripod is light enough to be carried then it's not sturdy enough. For a compact camera like the SD850 that likely isn't the problem. However, you can still shake the camera when you press the shutter release button. Try setting the self-timer. This allows time for the vibrations to die down before snapping the picture.
In your particular case, I think we can assume that the subject isn't moving, so #2 doesn't apply. To assure proper focus, make sure the painting is flat and perpendicular to the lens axis. If the painting is tilted relative to the camera, then different parts of it will be at different distances and the camera won't be able to keep all of it in focus.
Also, make sure the front of the lens is clean.
Feb 03, 2012 | Canon PowerShot SD850 IS Digital Camera
Curser is set to move by the arrow keys. how di I get it to go back so I can move it through my keypad
most probably you accidently hit the scroll lock button.
press the scroll lock button again.
-----Original Message-----
I must have hit a control function. Now instead of
moving up/down/left/right
in
individual cells, I am moving the whole page. Any Ideas?
Thanks
Ike
Oct 04, 2010 | Acer NSK8458AN Keyboard
Arrow keys moving whole page instead of cells
highlight a cell then try using the arrows
Dec 30, 2009 | Logitech 967437-0403 Keyboard
Keypad problem
u have to change the keyboard !!!!!the circuit connections would have been distorted
Jul 22, 2009 | Nokia N72 Cellular Phone
Focus area
On the back of the camera to the right of the screen is a sliding button type thingy switch it from L to the dot and then move focus with dpad control above . Hope this helps
GWP
Sep 19, 2008 | Nikon D70 Body Only Digital Camera
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
