Question about Kenmore Dishwashers
Rolling trays need to be replaced
It is time to replace the roller trays for my kenmore dishwasher.it is one you can move around.Modle#110774190 /Stock#77419 / 3.4amp motor evrerything else is good but the devider pegs and utencile tray are in bad shape.Can thay be replaced and where can i find them if so?
    President:
  • 704 Answers
You're missing some digits for your Kenmore model number, so I can't provide with a direct link to the parts list for your particular model.
However, if you can get all of the digits, including the pre-printed ones, on the factory label, you can go to www.searspartsdirect.com and obtain a parts list and line drawings that show all available parts for you dishwasher.
If you are having trouble determining what your model number is, you can also give Sears Parts hotline a call at (800) 252-1698 and they'll assist you with getting the model number and provide you with the part numbers for the replacement parts you're looking for.
The parts you're looking for are typically available. But if the cost of those replacement parts is more than 50% of the cost of a new dishwasher, you might want to consider if a better choice for you is replacing the unit, rather than spending more than $150-175 on trays and racks. Think about any future other component issues you might encounter, as they would likely put you in the price range of new Kenmore dishwasher.
I hope you find this Very Helpful and best regards!
Posted on Oct 01, 2009
Roller
If nothing happens no carrier movementor paper feed you probably have a bad keyboard.
If the carrier moves but no feed the index motot may need to be lubed.
If the roll moves but the paper dosen't you may have debris on the paper tray or bad lower fed rolls.
DickyO
May 03, 2013 | Lexmark Wheelwriter 1000 Typewriter
Kenmore Dishwasher: Our dishes are not getting clean anymore.
This sounds like the sprayer arm isn't rotating freely.
Open the dishwasher and pull the bottom tray forward (remove it if you like)
Reach in and try to rotate the sprayer arm. It should move freely. If you give it a quick flick, it should spin around at least one full revolution before coming to a stop.
Sometimes these become blocked by dishes or plastic bags in the bottom of the dishwasher, other times they simply wear out and you'll need to replace the arm assembly. When I replaced this for our GE dishwasher this spring, the total cost was around $38 for the parts. The replacement took less than 5 minutes, with no tools.
If you want help tracking down replacement part numbers or a source to buy them, comment back here and I'll google them up for you.
And of course, if this helps you, please be sure to hit the thumbs-up button for me!
Dec 14, 2009 | Kenmore Dishwashers
In my Selphy 710, the paper wont feed from the tray to the printer. The rollers are rolling, and the paper gets pushed up to the rollers, but Im not sure if its not gripping the paper, or if the timing is...
sounds to me like the Pick up rollers need to be replaced, you can try to manually clean those rollers with some rubbing alcohol and some q-tips and gently clean those rollers, if that doesn't help then the rollers need to be replaced. You can usually find replacement pick up rollers online
Nov 18, 2009 | Canon SELPHY ES1 Thermal Photo Printer
Moves the roller up and down all the time and doesn't roll
The plastic slider is broken that moves the press onto the roller.
when you slap against the underside ,where the motor is of the press,and you hear some plastic parts rumbling around ,than that's probeby the broken parts with the plastic ring that fell of the wheel.
This plastic sliding part is atached to the press and needs to be replaced.
Can't help you with the part's ,need the part's to for my miele b890.
Oct 24, 2009 | Miele Rotary B890 Iron
GE Nautilus top roll out tray
Although most GE roller assemblies are universal...you will need the model....#...(which you will find on the inside of the washer on the wall of the drum).....but here is a part number and the link to get exactly what you need
Item #
2287
http://www.repairclinic.com/GE-Dishwasher-Parts?s=a9b3
this should get you going this place is great I have used it many times....and fair pricing.....
Good luck, good day....and thank you for rating my effort....The Fang.
Mar 19, 2009 | GE Nautilus 24" Built-in Dishwasher
I can't reatach top( glasses) rack I can't figure out where the clips go into.
The clips attach to the upper tray assembly...you clip the little roller assemblies (all one piece) onto the bottom of the tray...along the lowest part of the tray...when clipped in place...(I'm not sure but there will be an even # on both sides) you then put the tray back into place and it will roll inside or along a silver track...which may have a slot cut out where the rollers drop down into and then the tray is pushed back...into place and the last roller drops into the slot and the tray will extend along with the arm that the rack is sitting in/on.
I hope this helps...any more ??...just ask....good luck...thanks for rating my effort...The Fang.
Feb 19, 2009 | GE Nautilus 24" Built-in Dishwasher
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Dishwasher: upper tray rolls out everytime the door opens
put 2 small pieces of cardboard under the front legs until you get it where it wont roll out anymore. i had the came problem with my kenmore and it took care of it
Dec 28, 2008 | Viking DFUD142 Built-in Dishwasher
HP Business Inkjet 2800 - A3 Problem
Separate the Tray 2, on tray2, u would c couple of while rollers.. check how do they roll and clean for any dust.. While rolling if u feel any friction or any of the rollers broken.., then u need to replace tray 2.
Jul 15, 2008 | HP Business InkJet 2800 Printer
Paper will not feed
What you need to do is remove the tray, and look for the feed rollers and clean them with either alcohol or a soapy cleaner like Fantastic.
Clean them a few times, make sure they are dry then try again.
That may solve it completely, or your rollers may be slick and need replaced.
When those rolls get dirty, it's like trying to drive on ice. You just slip. Also, if those rolls are needing replaced, I wouldn't be upset with the refurb work. Sometimes those rolls fake you out. They appear and to touch feel perfectly fine, but try and feed a piece of paper, and it just won't.
If you can, look into the paper tray with a flash light, and see if they are turning. If they are, then dirt or slick rolls is the only problem you have.
Mar 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
