Brother laser printer printout
I have a brother laser printer all in one 8660.  I just replaced the toner with a brother cartridge and the print outs have little black dots regularly spaced about an inch and a half apart running verticly down the extremem right edge of the paper and about 2/3 across from the left to the right side.  i tried re-shaking the toner and i slid the wire cleaner back and forth but they remain. What to do?
  • 3 more comments
  • Anonymous Mar 26, 2008
    I have the same problem: four dots keep printing on the left hand side of the page. Tried shaking the toner cartridge but to no avail.
  • gest graphx Oct 24, 2008
    my brother mfc-9440cn always print 4 dot a the right side of the paper. i'hv try a lot of thing but nothing can remove it it's a big probleme cuz i need it to produce material fot the customers
  • Anonymous Nov 28, 2008
    I have a similar problem on a Brother HL 5040 with three dots spaced about two inches apart on the left side of the page.
  • Anonymous Mar 10, 2009
    I think I have the same problem - there are dots evenly spaced just on the right edge of my paper. I also replaced the toner today... I also tried tilting the the toner right and left but it still didn't work. Help would be very appreciated. Thank you in advance.
  • Karl Emmerich
    Karl Emmerich Jun 14, 2014
    I have the same problem -- HL-4150CDN -- the printer is only 2 months old
The link has been removed by Brother. It must have been really working....
Could you post the instructions directly. TY
Posted on Oct 26, 2009
You need to clean your drum unit:
see http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001044&Sympt=The+print+jobs+have+black+spots+or+black+dots.+How+can+I+improve+the+print+quality%3f&Model=3&ProductGroup=1&Keyword=dot&ProductID=HL2040
Worked for me!!
Posted on Apr 11, 2009
I tried the solution posted above - it really worked! (note - the part to clean is the reddish film-looking part, not the black toner!)
Posted on Oct 01, 2009
What does the drum do on my brother printer
The drum is the component that actually transfers the image onto the page.
Laser Printing 101. When a page is printed to a laser printer it is transferred to the laser printer via the network or usb cable using the driver installed on the PC. This information is then converted back into a format the printer can print through the Format board and the internal firmware of the Printer. This information is then transferred to the drum via a laser beam to a photo-sensitive film on the surface of the drum which is charged and allows the toner from the toner cartridge to stick to the drum which is then transferred to the page and the page is then fed through a Fuser (A heated roller which operates somewhere around the 300-500 degree cetigrade point) to fuse/melt the toner onto the paper which is then fed out to the paper cachment area you collect your printout from.
I hope that helps with your understanding.
Aug 13, 2014 | Brother MFC-8880DN Mono Multifunction...
MFC-9840 printing Yellow/Red/Blue strips in background. Any ideas why?
This is caused mainly by leaving the Corona Wire sliders anywhere other than where the arrows on the slider meets the arrows on the Drum Units. This leaves solid lines of colour down the length of the page (one per colour with the slider in the wrong place) if it is leaving more than the single line on the page it is probably leaking cartridges.
These particular cartridges are known for their ability to leak badly (OEM and Remanufactured cartridges do it). The only option for a leaking cartridge is to replace it and clean out the machine with a lint free cloth preferably a 'Toner Grabber' cloth. If you nee one of the toner grabber cloths then talk to your local cartridge refilling place for one. If they refil toner cartridges there then they probably have them or can suggest a different option.
Aug 12, 2014 | Brother MFC-9840CDW Laser Printer
Drum & toner were replaced and now the printer PRINTS IN CHARCOAL have replaced the drum and toner twice
I assume "Prints in charcoal" means dirty printouts. The toner is not staying on the paper?
Sounds to me like a bad "Fuser Assembly" problem.
You can source one from:
http://www.precisionroller.com/fuser-assemblies---units-for-brother-hl6050d/details_38855.html?src=gbps
Hope this helps
Mar 14, 2011 | Brother HL 6050 Laser Printer
I have a Brother MFC-7340 and recently replace the toner and now the background is dirty looking when I print, ie grey where it should be white! What can I do to clean it up? Thanks!!
Either you purchased a a bad quality remanufactured toner cartridge or your fuser film is damaged.
If there is some kind of debris in black color that is on printouts, your fuser film might be damaged. Have a printer technician replace it.
If there is no debris, only bad quality printouts, it's the toner cartridge that needs replacement.
Mar 05, 2011 | Brother MFC-7340 All-In-One Laser Printer
Replace cartridge error
i have brohter dcp7030 laser printer .earlier toner is empty si i refiiled the toner but toner giving me not printout.printer is display the message of toner end so plase me suggest the reset of this ptinter
Oct 28, 2010 | Brother DCP-7030 Digital All-in-One Laser...
Just before I needed to replace the toner cartridge, I noticed some spots occuring on the printouts. Same spot, 3 different times in a line down the page. I had hoped that replacing the toner cartridge...
Have you checked the Drum unit...inside the drum unit there is a PCR- photoconductive roller which worn out and it sometimes casues the issue, if not then check the fuser pressure roller
Sep 22, 2010 | Brother HL 2140 Laser Printer
My printouts have a very dark haze over them.......the printed letter are fine but it looks like the print cartrige is dumping ink on my paper as it prints. It look like a bad fax copy. What is the...
May 31, 2010 | Brother HL-2040 Laser Printer
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
Replaced toner cartridge and now get printout of
try to reinstall the printer driver. then align the printer toners. then perform some test print.
Mar 08, 2010 | GCC Technologies Elite 12/600 Laser...
Printer problems
PULL OUT TONER CARTRIDGE SHAKE SIDE TO SIDE AND REINSTALL
Jan 18, 2008 | Brother MFC 9700 All-In-One Laser Printer
1,799 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
