Question about Avaya AT&T Merlin Basic Telephone & Modem Interface - Refurbished (ATBTMI)
Divice goes to intercom not a outside line
At&t merlin basic modem and phone interface
divice goes to intercom not a outside line
Just dial 9.
If this is more of an issue of auto line select, we need to know the model of the phone system. Merlin 820? 410? 1030? 3070?
Posted on Sep 30, 2009
How can I change line voltage from 24V to 48V in KX-TA308 ?
Why? A TA-308 as well as all Panasonic systems run on 24 volts, even the TDA/TDE. The quickest way to do that, and very expensive, was a Proctor Long Line Adapter (46222/46224). The only time we ever had to use one was to bring up the line voltage of a Merlin Legend extension to interface to a Panasonic system we were using as a factory intercom. The intended purpose is for off-premise extensions as they provide high voltage ringing and protect the system it's attached on.
Proctor is long gone, but Viking Electronics makes an exact replacement. Here are the specs http://www.vikingelectronics.com/products/pdf/lla-4.pdf They also run about $500 for 4 ports.
Carl
Aug 29, 2011 | Panasonic KX-TA308 Phone
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
What is the code to program a Merlin BIS-10 to have only (1) incoming line. I have a 10 button phone and it thinks there are (5) incoming lines?
Enter admin mode:
Slide switch on left (T/P) down to the "P" position.
press the intercom button above TRANSFER
dial the 2 digit extension number you want to modify
Touch the buttons to add/remove the lines.
Green light on means line is active
Green light off means line is not active
Mar 24, 2010 | Avaya Merlin BIS 10 Corded Phone...
Lines 1 & 3 won't break dialtone on Merlin 410
Unfortunately no. The merlin 410 was an early phone system that didn't have much in the way of programming.
Sep 10, 2009 | AT&T Merlin BIS 10 Phone
Can you transfer a call to an outside line on the
Trunk to trunk transfer needs to be turned on for this feature to work.
Dan
Aug 06, 2009 | AT&T Merlin Plus 820D2 KSU Phone
How do you change number of rings for the phone and auto attendant
You need to go into phone system admin programming
feature 00
left intercom
left intercom
Then the program for the ring delay on the Lines:
VMS Hunt Delay
Dial #506
Release 2.0 and earlier:
Dial 1=Immediate
2=Delayed
Release 3.0 and later:
Dial 1=Day
2=Night
Dial line number
Dial 0-6
The delay for extensions is:
VMS Cover Rings
Dial #321
Dial one digit (1-9) for the # of rings
before the call is sent to the voice messaging
3 is default
Jul 22, 2009 | Avaya ONE-X QUICK OFFICE EDITION TRUNK...
Intercom doesn't make beeping sound only flashes Merlin phone sy
Depending on the type of merlin system you have, you should be able to turn the ringers on by moving the switch on the left side of the phone marked T . P to the "p" position. All the lights should light and the set should ring every couple of seconds. Press the line you want to ring and enter *37, repeat for all lines you want to ring. If you want all lines to ring , press any line button and enter *347, slide the T . P switch back to the center "." position.
Hope that helps
Mar 27, 2009 | Inter-Tel Axxess Corded Phone
Changing over from a 2wire modem with a basic phone line; running desktop with Ethernet cord, 2 laptops wireless. Can not figure out how to interface into my Linksys G 2.4 Router. Is there such a cord that...
run the telephone line from your modem into the wall jack. From the modem connect a network cable (cat5) into the back ( via the uplink port) of your linksys router . Your router can now route the IP from the modem.
Jan 26, 2009 | Linksys Wireless-G Broadband Router
Lands Phones Logo
123 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
