Question about Kenmore 19.7 cu. ft. / 558 liter Chest Freezer 13009
Picked up used chest freezer...plugged in and briefly clicks...I can hear it energized for about 5 seconds then quits....it then repeats this cycle. It was on its side when delivered
  • 358 Answers
Try to replace the compressor relay (most of the times problem) ,but if still doing the same clicking noise , the problem is in the compressor.
Posted on Sep 30, 2009
Won't turn on
To determine which component has failed please do the following.
Unplug the freezer wait 5 minutes and plug back in. Listen closely for any sounds by the compressor. If you hear a click or hum followed by a click the problem is the compressor and would cost about $400.00 to repair.
If you do not hear any sounds the problem is most likely the cold control or sometimes called the thermostat. The part number is WR09X10053 and is about $25.00
Apr 25, 2010 | GE 5 cu. ft. / 142 liter Chest Freezer...
Kenmore chest freezer wont cool
Hi.
Here is a tip that will help you...
There are also more tips at the bottom of this one...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
My GE chest freezer quit working. When I plug it
there is a chance that your over load and starter ptc has gone bad. the worst case your compressor has gone bad.
Feb 13, 2010 | Freezers
My haier 5.0 chest freezer model # hcm050eb has quit cooling. When I checked the compressor I hear it come on for about 3-5 seconds and then it shuts off for a minute before repeating this. I've unplugged...
your freezer is short cycling which is bad for the compressor. Usually there is an internal overload in the compressor that automatically resets as the compressor cools. Check to see that all of the coils are clean and the small fan is blowing. this will make sure that the airflow correct. look for signs of oil around the compressor, the coils, and any connecting tubing. if you find oil, this is a sign of refrigerant leaks. the refrigerant is what cools the compressor and it wont run long in an overheated condition. it will finally fail in the open position and not come back on.(compressor overload switch) If this is the case you may replace it cheaper
Nov 21, 2009 | Freezers
Freezer wont run
LIsten for a "clicking" noise that hums and then clicks. If you hear this the compressor is trying to start and it is what is called cycling on the relay. There is a relay and an overload device connected to the side of the compressor that starts it. The problem may be the relay/overload, or it may be the compressor. The noise will occur then repeat a short time(minutes) later. If you don't hear anything, it could be the cold control where you adjust the temperature. Find the control and with the power off, disconnect the wiring to it and try to figure out which of the wires plugged into it are the power leads.Often there is a ground with a stripe(often green in color) and maybe there is a schematic that will tell you. If you can determine this, jump the wires together using any method that will connect them. I often use a non-vinyl coated paper clip, make sure it is not touching metal and plug it in. If you hear that marvellous sound of power, replace the control. The control lead on chest freezers is uninsulated and is pushed into a hole in the freezer near the control and compressor. It pulls out and you push the new one in(I use some lube). If the relay is the culprit there are aftermarket ones available that have directions and are relatively cheap. Good luck, AJ
May 22, 2009 | Freezers
New chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Jul 13, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Apr 22, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
Kenmore Upright Freezer Model 2539252110
constant clicking, sounds like a compreesor trying to start itself, you might geta way with replaving hte starting device for compressor, sometime s a bad compressor will burn out a starting device, checl your warr papers, most compressors had afull 5 year warr
Mar 16, 2008 | Frigidaire 5 cu. ft. / 142 liter Chest...
Kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Sep 25, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezer not working, odd rythmic noise.
Is this the capacitor wires you are asking about perhaps?
Sep 08, 2006 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Kenmore 19.7 cu. ft. / 558 liter Chest Freezer 13009 Logo
147 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
