Question about Sony Cyber-shot DSC-W50 Digital Camera
Lcd screeen is black - Sony Cyber-shot DSC-W50 Digital Camera
Windex between screens
If the cloud like image is black then you have damaged your screen by applying too much pressure on the screen.
You should use special LCD screen spray and soft cloth to clean your screen to gently clean the surface of the screen.
Replacement :CD screen maybe available for your laptop from this WEB site.
LCD screens and Inverterswww.lcdparts.net
Apr 14, 2012 | Compaq Presario CQ62-219WM Notebook
I have a 37 in sharp lcd tv. it has a black line in the middle of the screen. looks like it burnt into the screeen. is this repairable?
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help.....
Jun 22, 2010 | Sharp Televison & Video
No picture on view finder
you need to request to replace your lcd unit to the service center.there's no chance to repair LCD.
Jun 03, 2010 | Olympus FE-280 Digital Camera
The screeen has gone black. The TV is only 2
The backlight inverter board may ahve gone out, or the power supply is not suppliyng 24vdc for the inverter board.
Sep 29, 2009 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Screeen
Check local repair depots in your area for a quote to repair it.......or if you have insurance, see if the damage is covered.
Nov 06, 2008 | Vizio GV42L 42 in. LCD Television
Monitor is on but disply id black
Having a similar problem.  When I turn my monitor on, the picture tries to come on, but then goes black.  After several times, I may get lucky and the picture will hold.  Is my monitor about ready to give up the ghost?  Mine is a few years old as well.
Jun 22, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
Monitor reads no connection
1. Check the cable connection to your PC. It might be disconnected.
2. If your have more then one cable input on your LCD monitor(VGA or DVI) check if you selected correct input; digital for DVI or analog for VGA.
Jun 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Help
have the flexcable or LCD replaced.
May 29, 2008 | Motorola Mobility RAZR V3
Sony Cyber-shot DSC-W50 Digital Camera Logo
29 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
