Question about Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 - Waste Tray is full
On the phaser 8200, what sensor determines that the waste tray is full? My printer boots up stating the waste tray is full even though it is not.
  • 208 Answers
SOURCE: Xerox Phaser 8550DP Printer does not recognize the ink it has
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes.
Posted on Dec 07, 2007
  • 2072 Answers
SOURCE: Xerox Phaser 8560 Waste INk
Although I agree totally, the anwer is no. Althought it appears black, take a piece of it an use it like a crayon. It is a combination of all the color inks combined. So if you take and rub it on a piece of paper it will be a purple color. So threfore would not create proper colors.
Now to save ink, Do not turn the printer off at all. Just let it use its own sleep mode. The power consumption is intermittent to keep the print head warm and uses about the same ammount of electricity as your refridgerator light bulb. The reason being, when you turn off a solid ink printer, it purges the print head of ALL old ink and dumps it into the waste tray. That is part of those weird noises you hear when you cycle up the machine, one is a compressor emptying the print head.
Also, honestly, althogh I am not sure what you are using the machine for. But you would be wise to put that product on a pay per page maintenance agreement. That includes all ink and all service. Some of the parts for those printers are super expensive.
I will say one thing you can do with that waste ink, if you know anyone who has children, they can use them as purple crayons..
Posted on Feb 21, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
Posted on Sep 11, 2008
pdouglasss
  • 125 Answers
SOURCE: Can I disable the lower print tray?
Hi wogan2:
Normaly when you get this problem it means that you need to replace the feed rollers in that tray.
Inspection
Rollers:
Replace the rollers when you see any of the following defects:
 Flat spots
 Out of roundness
 Cracked rubber
 Loss of traction (tackiness) causing pick or feed failures.
Xerox paper pick roller
Part # 401-0882-00
Hope this helps
Posted on May 24, 2009
komguy
  • 2306 Answers
SOURCE: Control panel show waste tray missing but the
I do remember a switch way inside that can come loose, but check for your error at
www.partsdrop.com a very helpful xerox site.
Posted on Sep 17, 2009
How do I replace a Transfix Assembly
There should be a door on the right side of the printer. Replace the maintenance kit and clean the waste ink tray.
Apr 14, 2012 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox phaser 8560 printer is saying waste tray missing but it is not
Are you sure you are looking at the waste tray, and not the paper tray? Here is a link to the user manual for the printer. Information about the waste tray is on page 194. This should give you an idea of were it is located.
http://download.support.xerox.com/pub/docs/8510MFP/userdocs/any-os/en/user_guide_en.pdf
hope this helps
Feb 22, 2012 | Xerox Phaser 8560/YN Printer
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
I have a phaser 7300 that asks for a transfer unit about every 3 weeks. It prints good until it asks for unit and then it will not print until I install a new one. I am ready to install the 4th unit but...
I think you might have a Spring missing for the Waste Toner Full Sensor. The machine tolerates the sensor status for 2K pages and then shuts it down.
Truthfully, it is really hard to describe in a few sentences. It belongs in the frame wall under near where you have the white waste toner section of the Transfer Belt. This spring pushes a flag up that hits the Paper Entrance Sensor (yes, near the bypass tray)
The PN for the spring is 116-2050-00.
Whit
Item, Inc.
May 21, 2010 | Xerox Phaser 7300DN Laser Printer
Waste tray message will not leave display panel even though tray is empty
You will most likely have to remove ( looking at the machine from the front) left cover and clean out some spilled ink from the waste tray sensor.
You have to remove one screw from the back top of the cover, then the top front of the cover. Lift up and out on the cover to release the tabs and pop the cover off. Then have someone slide the waste tray in and out so you can locate where that tray seats into the sensor.
Most of the time, some ink spills into that area in the back of the waste tray, and blocks it from sliding all the way in.
Jan 05, 2010 | Xerox Phaser 8500/DN Printer
Control panel show waste tray missing but the waste tray is in. This is a Xerox phaser 8550 printer
Sep 17, 2009 | Office Equipment & Supplies
8550DP
That usually is a sensor failing. You can try to locate it (in the area where the tray goes) and see if it is loose.
Good luck.
Dec 13, 2008 | Xerox Phaser 8500/DN Printer
Phaser 8200
Have you loaded both trays? The bottom tray and the upper tray ? The one that folds into the machine. Something may be trying to run from tray 1. Upper tray
Jul 17, 2008 | Xerox Phaser 8200 Laser Printer
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
Apr 17, 2008 | Xerox Phaser 8200 Laser Printer
Error Msg: Maintenance drawer A is missing - Phaser 8200
There is supposed to be an orange chip on the back of that tray.
If that is not present or seating properly that will cause that problem.
Pull out the green tray and see if the chip is snapped on the back ot the maintenance tray.
Oct 17, 2007 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
88 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
