Question about Kitchen Appliances - Others
The fuse in my Jensen JEN50 voltage converter blew and I need a new one. what size is this fuse?
    New Friend:
I own that JEN50 unit. It uses a .5 ((that is 1/2)) Amp, 250 Volt fuse.
Posted on Jun 17, 2016
    President:
  • 1,723 Answers
Look at he fuse on the very end of the fuse there are some numbers. Amps and volts, go by that and replace it with the same exact fuse. If not , you can damage the equipment
Posted on Oct 01, 2009
Is there more than one low voltage converter boxes
No there is only one converter. You will need to check the output of the converter using a multi meter. Check the negative and positive terminal where the converter is connected to the fuse panel. It should be putting out approximately 13.6v. If it is not then the converter is bad and will need to be replaced. If it is, then you need to check your battery. Some trailers require a good battery for the system to properly function.
May 28, 2014 | Keystone 2013 Cougar High Country 315RES
HOW DO I GET SOFTWARE FOR JENSEN JSCR50 CASSETTE USB
Either by purchasing a new unit from Amazon.com as linked below or by .zip file download from the attached links. Jensen Cassette Tape to MP3 Converter Free Download Streaming Internet...
May 18, 2014 | Jensen Pyle Cassette Tape Archiver And...
Can i change the fuse in the nintendo 64 power plug?
The current voltage rate for North America is 120 volts so you need the north american N64 ac adapter and use a voltage or a multi meter to check the ratungs.
Dec 15, 2011 | Nintendo 64 Console
I have a duo therm model 57915531. i have checked the breakers all the fuses and the thermostat. i have found a 3 amp fuse in the control panel of the roof unit. this fuse was blown. i replaced it and it...
That unit has a thermostat I believe and 12 or 24 volts to power it. The 3 amps tells me it may be either line or low voltage, see manual. the fuse blows due to a short in the control circuit, a transformer if low voltage.
Sep 10, 2011 | Dometic Rooftop RV Air Conditioner
I'm in Iraq and I brought my ultratone k450fx with me to play my korg synth and being exciting to finally be able to play I plugged it in without using a transformer and blew a fuse, what size do I need to...
In Iraq I assume the voltage is 220-250.  The fuse you'll need is a 220-240V 1.25A H 250 V.  You can actually use this model without a transformer/converter if you have the voltage selector set to the non-North America setting.
Play well!
May 17, 2009 | Behringer Audio Players & Recorders
Jensen LXA400 Fuse Size and RCA hook up for 2 channel mode?
take it to a stereo shop. there are variables you may not be aware of when hooking up speakers to an amplifier like ohms, very important!
Dec 08, 2008 | Jensen LXA400 Car Audio Amplifier
Plugged 4w 120v trimmer into 220v outlet with a 50-2000w 220-110v coverter - it blew fuse and doesn't work. soldering melted off wire inside
scrap the trimmer...
probablly damaged beyond cost of new one
a step down transformer would have been a better choice than a voltage converter ( not trying to be a wise guy here)..
Nov 04, 2008 | Remington HC-600 Hair Trimmer
No Power... need a new fuse.
While wiping off the dvd vhs player it went out. Said it did not recognize the tv anymore. My son put it on his tv and got a half screenof the movie. just took out the fuse t2al 250v. what is my problem?
Sep 11, 2007 | Cyberhome CH-DVD 300 DVD Player
Kitchen Appliances - Others Logo
507 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
