Question about Plumbing
Leaking Selkirk Gas Vent flue.
I have a Selkirk Gas Vent 1200/H4 flue that has developed a leak on a joint. Can the joints be resealed?
  • 129 Answers
You can use metal tape.
Posted on Oct 05, 2009
Ac Gas keeps leaking..
It seems no one has tried to find a leak, should not refill without leak checking. Where there is a refrigerant leak, some residual oil will appear, refrigerant and oil circulate and move together. The system should be cleaned so that any new oil leaking will mark the leaking area or spot when leak testing produces nothing. When no leaks are detected, a dye can be used to mark the leaking area.
Leaks are common to develop on joints where seals are present and where hose is crimped to solid tubing. I don't recommend leak sealer additive into the system.
Jul 15, 2015 | Renault Cars & Trucks
I am experiencing a leak under my well's pressure switch. This is occurring at the site of the copper stalk and the PVC after the tank T. What do I use to reveal this join?
I use paper towels stratigicly placed to find the actual leak. It may be a bad solder joint, or it may be a bad PVC joint, depending of the actual source. You may need to "start" over, with new materials and connection methods.
Apr 27, 2015 | Air Tools & Compressors
Moister in headlight, how do you remove and can you reseal it
These are not fully sealed housings.
They have two vents on the back side.
However, if the rubber seal on the top that covers the seam for the front and back is poor/leaking, that leads to too much water getting in to vent out.
Inspect integrity of the housing. Make sure everything is sound. If something looks like it might allow water to bleed in, use some silicone sealant (heck, even duct tape) to cover the area.
Inspect the vents and make sure they are not blocked somehow.
Give it some good, hot summer days in the sun (I know, we all need some of those) or drive with the lights on to heat up the housings and vent that moisture out.
Mar 19, 2015 | 2000 BMW 528i
MY POWER WASHER WAS LEAKING , WHAT HAS TO BE DONE?
Leaking from the pump is often due to a freeze problem and will not generate pressure. Other leaks should be fixed by resealing the joints.
Sep 30, 2014 | Garden
There is a smell of fumes. how do I service this problem. It is a kozy world wall gas unit, with 3 burners.
take sm. bowl and mix dish soap and water real bubbly,turn on gas,take sm. paint brush and paint soapy solution on all heater joints that contain gas and watch for bubbling bubbles,and thats where your leak is,but don't stop with the 1st leak you find,there may be more..check all joints, start with house plumbing then factory heater piping,,once all found ,mark them as you find them...then shut off gas and reseal and or retighten leaky joints....
Nov 28, 2012 | Heating & Cooling
Cracked Selkirk METALBESTOS gas vent pipe on 80% efficiency furnace (Trane XE80)
I would check with a local furnace company that installs Tranes and ask if they sell to the public, if so buy it.
Oct 12, 2012 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
My car smells like exhaust more than normal when I turn it on why.
As exhaust parts get older, the flex joints, and any moving seals wear and allow more fumes to leak.
Sometimes, a hose can start leaking related to the emission system allowing fumes to escape.
Usually a flex joint will develop a leak more rapidly if the motor mounts and torque struts allow the engine to move excessively.
You can start it cold, and with your hands around any sealing areas, should notice the exhaust leaking. Have a friend push a rag up against the tailpipe to restrict the flow, as you listen up front for leaks.
Good luck !
Mar 29, 2012 | 1993 Ford Probe
My reliance sta-kleen 502 is leaking. The water is dripping on top of the pilot light, extinguishing the flame . Please advise me with step by step instructions to diagnose and attempt fix this myself....
If you have a leaking water heater there is a serious problem.
http://waterheatertimer.org/Water-heater-leaking.html
Page shows how to limp along on a leaking water heater if your water heater needs replacement.
One of three things is causing the water:
1) Loose water connection on top of tank that is dripping down inside tank >> check pipes on top of tank.
2) The vent is clogged or not working correctly causing condensation inside flue pipe.
Condensation water is dripping back down inside tank.
Problem means possible CO poisoning if gas is not venting.
Look at vent pipe to see if joints are corroded.
Use long fireplace match > light match and put into draft hood at top of tank and see if smoke goes up.
Put hand at draft hood opening when water heater turns on to see if vent gas enters home.
Do same test when furnace turns on to see if furnace vent is pushing back into water heater.
Does water heater vent inside same pipe as furnace? You may need to set up separate vent for water heater if furnace gasses are pushing back into home.
Check furnace vent for obstructions.
Look at vent stack top of home to see if hood is in place.
Check if bird nest is built inside warm vent pipe.
Improper flue is top priority for getting fixed so vent gasses properly escape home.
You may have to call a plumber.
Professional plumbing forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Your water heater is rusted out.
A rusted tank has to be replaced.
It cannot be repaired.
However, before replacing tank, you do not want a tank failure where tank ruptures and water runs inside home until water is shut off.
This will cause major damage.
Protect yourself first.
Turn off water valve above tank.
Move gas knob to 'pilot' so burner is not heating water.
Open tub spout on hot side to relieve pressure on tank so it will not rupture.
Now you're protected.
Link above shows how to limp along on failed tank until you can replace heater.
You need a new gas water heater from Lowes or Home Depot
Look at label on side of you tank for gallons and btu's of your water heater.
Measure height to flue pipe so you get same height water heater, so pipes don't have to be changed.
You need a pipe wrench and teflon tape which will be wrapped on each pipe thread when pipes are reassembled.
Step1) Drain water heater using valve at bottom of tank.
http://waterheatertimer.org/Water-heater-will-not-drain.html
2) Turn off gas valve going into heater.
When gas valve is perpendicular to gas line, then gas is off.
Dissemble gas line to water heater.
3) Disconnect flue pipe and support flue pipe with wire so it doesn't not fall down. Flue pipe joints should be held together at each joint with 3 screws.
4) Turn off water. Shut off valve is on COLD side.
Disconnect water pipes.
5) Move old water heater out of way.
6) Set new water heater in place. Put water heater in drip pan.
7) Connect water pipes >> cold goes to side marked cold.
Hot to hot.
Buy new flexible water connector pipes at home center for easy installation of water pipes.
8) Connect gas line exactly as it was connected before.
Home center sells flexible gas line connector for easy installation of gas line.
To test for gas leak after installation, mix liquid soap with water and put around gas line joints to see if there are bubbles.
Natural gas has less pressure than water lines, so gas pipes are easy to seal with ordinary wrench.
9) install TP pipe that runs to floor. Use old one off old heater.
10) Fill tank completely with water until water is coming out of tub spout.
11) Turn on gas, and light pilot as shown in manual.
New gas heater sometimes have small water leak when first fired up, so ignore a bit of water.
12) Save water heater manual like it is gold, and read everything in manual.
Dec 18, 2010 | Water Heaters
Gas Water Heater leaking
If the tank is fairly new you me able to reseal the leaking fittings. You will have to turn it off and drain, then remove the leaking fittings and reseal them with pipe joint compound or teflon pipe tape.
Aug 14, 2009 | Rheem Gt199dvn Heavy Duty Tankless Water...
Plumbing Logo
210 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
