Question about Makita 9 Hp 4,300 Watt Portable Generator #G4300L
My makita 4300l generator runs for a brief period(5 to 10 minutes) and cuts off. Check filter and gas. It's a brand new generator only has about 45 hours
  • 98 Answers
It might be the carburator....replace it and see what happens..
i hope i helped...send me an email for more details
Posted on Oct 11, 2009
Makita concrete saw, no spark, new ignition coil.
Check clearance between the coil and magnet, too far away and magnetic field won't generate.
Apr 13, 2012 | Makita DPC7311 73cc 14Inch Gas Powered...
The machine runs for brief periods, then shuts itself off. If it is allowed to sit for several minutes, it runs again, then shuts itself off.
the motor is heating up to much and the cut out switch is kicking in. You need to check the the motor filter, and worse case you may need to new motor..
Oct 04, 2010 | Dyson DC14 All floors Bagless Upright...
I have a proforce 2500 watt generator and it cuts out is this caused by low oil? if I change oil how much does it get?
Low oil doesn't usually make engines cut out. Clean the air filter, change the plug and wire. If this doesn't help then I think you're looking at a carb. problem. Probably just clogged jets & ports. It's very common on small engine carbs. It shouldn't take more than 2 quarts of oil. Probably not even one.
Nov 30, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Oct 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Sep 07, 2009 | Master Heaters MASTER HONDA POWERED...
My honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
Sep 06, 2009 | Master Heaters MASTER HONDA POWERED...
Makita G11oo portable generator. starts on choke. cuts off run
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
May 21, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Makita Generator G2800R
Check your tank for contaminants (water, trash, dirt, monsters, etc), as well as the balance of the fuel system. You may also need to remove the carburetor and clean it out, particularly if the generator has sat for more than a month with fuel in it (most do, including mine) and now has deposits. The only thing that the choke does is make the mixture rich by cutting off the air.
And just for grins, look at the spark arrestor screen on the muffler. This can be related and problematic as well.
Mar 10, 2009 | Makita 2,800 Watt 6 Hp Portable Power...
Makita Generator suddenly stops has gas
Hi
Hi See if the gas tank cap vent is clogged,remove the cap and check the gasket in it.Check the flyweel key(not to be sheared) and the condenser( not to be defective).The ignition points(not to be burned).Check the oil in the crankcase(pay attention to the low-oil-level shutoff sistem (if there is one).Check the fuel lines and filter.Check the muffler(not to be clogged).Check the plug wires and make sure is securely attached at the sparkplug.Check the cable and linkage.
best regards savumihai71
Dec 15, 2008 | Makita 9 Hp 4,300 Watt Portable Generator...
Makita 9 Hp 4,300 Watt Portable Generator #G4300L Logo
192 people viewed this question
Top Makita Electrical Supplies Experts
obsteiner
Tom Chichester
Ogbonna promise
Are you a Makita Electrical Supply Expert? Answer questions, earn points and help others
