Panasonic Plasma HDTV Model No. TH-42PZ80U GPF11DU Chassis:I'm a tech with SM for this gem. When powered up, blink code of 2 per cycle. Manual suggests 15v SOS problem on "D" Board. I have replaced D Board. No change. On initial powerup, fans run ~2 seconds. Watching 15V (P) line, 15v is not achieved and voltage present collapses. Other voltages can't be checked, as circuit goes in to shutdown. Can the power supply run unloaded for test to rule out SOS line failure in other "boards"? "A" board has also been replaced.
  • 1 more comment
  • electrepair Sep 30, 2009
    Are we talking about the same unit? The 4 fans on this unit are mounted at top for heat dissipation of all boards, to include HV drivers. Have you had experience with Panasonic Plasmas with similar problems? Are you working w\ a service manual?
  • electrepair Oct 10, 2009
    As stated in initial post, the unit will not power up long enough to measure the all the supply voltages. Do these supplies fail frequently? What about the HV drivers? Is there such a thing as a dynamic short? The indicators on SS & SC boards are not lit. Are there other indicators that should be monitored?
    With system monitor lines open, power supply will not turn on. No relays cycle. unit completely dead. Please remember the power supply monitors SOS status of all the derived supplies in the supply. That's why I can't make it run long enough to isolate the problem area.
  • 6,927 Answers
There will most likely be a cold solder joint under a board,that you haven`t replaced,that holds,and connects a heat sink to the board.Just clean,and re solder the joint.Hopefully,this helps you,but nearly all the projections have this problem a some time.The robots at the manufacture make these mistakes. I hope this is some good.
Posted on Oct 11, 2009
    Genius:
  • 1,036 Answers
Problem is with excessive drain or short on another board fed by this PSU. Should be able to run this with other boards disconnected. Reconnect items untill faults reappear. Replace defective board when isolated unless you have expected current draw information for relevant boards.
Posted on Oct 10, 2009
    President:
  • 1,723 Answers
Watch the power supply voltage during start up. Verify all voltage levels are correct and steady. This happens when a bad solder joint is present, trying to pass current. Focus on the power supply voltages during loading.
Posted on Sep 30, 2009
  • Craig Butler
    Craig Butler Oct 10, 2009
    I would try to unhook all the load connectors coming from the power suppl board. Then test all the voltage levels. Hook up the load connectors one at a time and watch the power board for reaction.
  • 3,741 Answers
NO the power supply run cannot be unloaded for test to rule out SOS line failure in other "boards".its not possible. check out the fan getting hot at its base where the connection is.it should not get hot.if its getting the connection is getting overheated on the board.check out.thanks.keep updated.
Posted on Sep 29, 2009
I have a Panasonic model TH-42PZ80U Plasma Tv the red light keeps blinking 10 times and it won't turn on?help
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
Jul 18, 2011 | Panasonic Viera TH-42PX80U Plasma TV
My Panasonic TH-42PZ80U has a blinking light. It blinks two times.
Generally a two blink code means a faulty power supply. You can buy a replacement power supply online. I've seen them as low as around $120. I'm doing factual research for a potential class action lawsuit regarding these blinking light problems, so I'm pretty familiar with this stuff now. From most of the complaints I've seen people post, if you have a tech replace the power supply it usually costs between $450-$600 including the tech's labor time.
I'd like to hear more about your personal experience with the television. If you would be willing to share your story with me, please send me an email at kiaeger@levjen.com.
Oct 15, 2010 | Panasonic TH-42PZ80U 42 in. HDTV-Ready...
TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Apr 27, 2010 | Panasonic Viera TH-42PX80U Plasma TV
My panasonic hdtv th-42pz80u has a red power light that blinks on and off and the tv will not turn on. how do i fix this?
How many times is that light blinking? For example a 7 blink error code would blink 7 times pause 7 times etc. What is your's blinking?
Dec 10, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panny TH-42PZ80U Plasma TV No display on Power-up
I had this same exact issue. Panasonic sent a repair tech to my house since I was still under warranty. The tech was able to fix me up in about 10 minutes. He replaced the "brain" or A-board and now I'm back in business. This is NOT a power supply issue. The brain is the circuit board that has all the inputs attached to it (component, hdmi, etc...).
hope this helps!
Aug 02, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Trying to find out what parts needed to fix panasonic th-42pz80u
If your TV model is TH-42PZ80U, and you want to replace the whole power supply unit, shopjimmy.com has them for $160. But for each parts# on that board itself, you need to find a Service Manual to look up that part.
Feb 02, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
