Question about Honeywell Programmable Thermostat Heater
Thermostat I CANNOT PROGRAM THE TERMOSTAT
  • 1 more comment
  • eephant Dec 19, 2007
    RTH230B honeywell thermostate (programmable) I need toknowhow to program (once) to have the heat stay on 69 degrees, Monday through Sunday
  • Anonymous Jan 04, 2008
    I have a T8000 Honeywell Thermostat - need to know how to program only once - for constant heat throughout the day at 68 degrees and down to 66 at night. Owner's manual only gives options which don't work for me as I am home throughout the day and night.
  • Anonymous Jan 06, 2008
    We purchased a T8700C Honeywell Electronic Round Programmable Thermostat. I have the owner's guide and have followed the instructions to program the unit for 60 degrees day and night. Impossible! It doesn't work the way the instructions are written. Maybe it's me. Help!
    I turn it off and freeze or sweat to death at 68 degrees. This is a sun room- an addition that has electric base board heating. We're not always in the room.Next time - no programmable for me!
T8000c it is not showing any thing, wont turn on
Posted on Jan 24, 2010
I have a Honeywell Programmable Thermostat, T8011R. The users guide for the T8000 series can be found at:
http://www.honeywell.com.au/business/acs/acp/ecc/ec/residential/identify.html
To keep your temperature at a single setting, just enter the temperature at every period, i.e. WAKE, LEAVE, RETURN AND SLEEP for both the Monday through Friday time frame and the same for the weekend. I do this at 55 degrees when I'm going to be out of town.
To 'Guest' , enter your 68 degrees at WAKE, LEAVE and RETURN, then enter 66 degrees at SLEEP. Do this for the Monday through Friday time frame and again for the Saturday - Sunday time frame.
Posted on Jan 05, 2008
What causes the printer to start printing faded
long warm up, the termistor termostat did u check and clean *28* program fixing unit
Feb 19, 2013 | Canon imageRUNNER 5000 Copier
Where is my thermostat
the termostat on your 2004 trail blazer with the 4.2l in line six is located under neath the alternator you have to remove the alternator to remove the termostat.
Feb 08, 2012 | 2004 Chevrolet TrailBlazer
How to change thermostat
The Termostat fit inside the Termostat Housing. It normally links to one of the radiator hoses leading from the engine block or radiator. Depending on the model you have, the termostat housing needs to be opened, the old termostat removed and the new termostat inserted. It's quiet simple. Before closing up, make sure that the both surfaces on the housing are clean and free from dirt and old sealant. If you remove a gasket, then replace with new gasket. If the housing takes a rubber O ring, then it is advisable to replace this.
Good Luck
Dec 29, 2011 | 2004 GMC Yukon
Coolant returning to reservoir
check your termostat, engine termostat if defective will result same with your problem...
Nov 22, 2010 | 1989 Volkswagen Jetta 2 Door
Is over heating, has new ratiator, termostat, hoses, sensor in the termostat and still over heating
Does the electric fan work...if not the thermatic sensor is faulty, quite common.
Oct 15, 2010 | 1999 Honda Civic
KIA SPORTAGE 2001 OVERHEATING WHILE IDILING
Visco fan or termostat problem. Fan not working 100% or stuck termostat
Mar 26, 2010 | 2001 Kia Sportage
How conect termostat
The thermostat is located where it leaves the upper hose going to the radiator and remove 2 screws in that box is located the thermostat
Jan 09, 2010 | 1993 Dodge Caravan
Need to replace thermostat
USING A PAIR OF PLIERS RELEASE HOSE CLIP AND DISCONNECT THE HOSE FROM THE THERMOSTAT HOUSING LOOSEN AND REMOVE THE THERMOSTAT COVER BOLTS AND CAREFULLY THE TERMOSTAT COVER AND WITHDRAW THE TERMOSTAT FROM HOUSING REPLACE NEW TERMOSTAT ,RE FITTING IS THE REVERSE OF THE REMOVAL, BEARING IN MIND IN THE FOLLOWING POINTS ENSURE THAT THE THERMOSTAT IS CORRECTLY LOCATED IN THE HOUSING AND FIT A NEW SEALING RING .
Oct 24, 2009 | 1996 Volkswagen Passat
Termostat
Simple! Your motor will Overheat and Stop causing you to have to get it Rebuilt. If you Follow the Top Radiator Hose to the Block there is a Bell Housing that the Hose Connects to. Remove the Hose and the Bell housing. Thermostat is Under the Bell housing, Looks kinda like a U.F.O.! LOL
Jan 15, 2009 | 2001 Chevrolet Impala
Heating & Cooling Logo
703 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
