Question about NetGear DG834G Wireless Router
My router wireless transmission is not working and the light (for wireless transmission) is not coming on. All other wired connections are working. How can i fix this?
  • 1 more comment
  • stewartm7 Sep 30, 2009
    Thanks for the suggestion above. My router is a dg834g v2. The strange thing is that when i connect to the router the option for wireless settings is no longer available. i have tried resetting the router with no success.
  • stewartm7 Oct 01, 2009
    I have upgraded the firmware to the latest version. But i still can not see the wireless settings.
    i will definately try this approach. We had a lightining storm in the area is it possible that that could have caused the wireless to malfunction.
  • 68 Answers
Which version of dg834g do you have
its its v5 then it has a button located on top of it that enables/disables wireless connection
maybe you accidentally disabled it
if its any other version of dg834g the you can enable wireless transmission through the router page
Connect to the router by typing
http://www.routerlogin.net in the address bar of a browser.
if it asks for the id and password enter
id = admin
password = admin or password or leave it empty
these are default id and passwords, if you have changed them enter the id and password that you know
go to Wireless Settings
click on the checkbox that enables wireless transmission
save settings
and you are done
Posted on Sep 29, 2009
  • Aseem Sep 30, 2009
    if you are not able to see the wireless setting option that means that your firmware has been corrupted
    go to netgear website
    go in their support section and download the latest firmware for your model of the router
    then install that firmware through the router page under backup settings
    then you will have access to the wire less settings
  • Aseem Oct 01, 2009
    this is a direct link to the wireless settings
    http://192.168.0.1/setup.cgi?next_fi...&...
    i checked around the net to find similar problems and came around a fix
    if u have a little technical expertize you should try this
    try this is you accidentally dropped your router
    Disconnect all cables,open the case( 4 small hex tamper proof screws
    under the rubber feet.You may need a Torx driver or a small flat
    screwdriver works) Open the unit up carefully. The Wireless part of the
    router is on a removable SIM type card attached to the main PCB.This
    little PCB card dislodges when dropped occasionally.Just plug it back
    in and your in business.Then access the router's web brouser interface
    and check your settings. All should be OK
    tell me if it works
N Wireless Modem-Router F5D8633au4A: every light on my belkin N wireless router is on e...
WIRELESS LIGHT WILL LIT UP IF YOU CONNECT ANY ANY WIRELESS DEVICE TO THE ROUTER.. FOR EX: YOU CAN SEE WIRED LIGHT LITTED UP BECAUSE YOU CONNECTED A COMPUTER WITH HELP OF ETHERNET CABLE.. IN THE SAME IT WILL WORK...
May 17, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I just bought a Belkin Router Model # F5D8236-4. I have everything wired correctly, but the wireless light does not come on. I can't get the internet to come on to the computer I want to connect to? What...
Wireless light will lit up only if any wireless computer is connected to Belkin's wireless network.
First, connect to Belkin's wireless network that you can scan.
After you connect, try to go online
It ll work...
Jan 21, 2010 | Belkin (F5D8231-4) Wireless Router...
The only light on my router is the router light. No other lights are coming on. I have tried rebooting.
When facing the router, Globe/Internet LED is on the right. Below are the LED indicators; Check the steps below:
Wireless Security - This light will only turn on if the wireless security is enabled.
Wireless-Computer Status - This light will turn on if a wireless computer is connected to the router.
Wired-computer Status - This light will turn on if a wired computer is connected to the router. Connect the wired computer to any gray port on the router. (There are 4 gray ports).
Router Status - Power light. Solid blue means the router is on and ready.
Modem Status - If this is off, it means the router is not connected to the modem. Make sure the cable is connected from the modem to the yellow port on the router.
Internet Status - This light will indicate if the router is connected to the internet.
If this is the first time you are installing the router, then what is important is to get the router, wired-computer and modem lights ON. Once they are on, you may insert the CD that came with the Belkin router to setup the internet connection and wireless settings.
Dec 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I have two desktops and one laptop on my di-524. One desktop no longer connects. The others are fine. Is this a router or adapter problem? I tried a d-link 'stick' but after working for one day, it no...
One desktop and 1 laptop are working that means your router must be working.
1 desktop is not working. Is that wired to the router or wireless ?
If it is wired then check the light on the router, If your computer is connected to port 1 of the router then port 1 light should lit up. If the light is not lit up then check the connection.
If the light is lit up then check the IP address on the computer.
If it is wireless desktop then check the wireless connection.
Click Here for more info
Nov 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Belkin Wireless G Plus MIMO router - connectivity problem
Connect one computer directly to the DSL modem using an Ethernet cable. If your DSL service includes a static IP address, then you will need to change the TCP/IP settings on your computer to connect directly to the DSL modem. that the router or other device on your network . For these you need to follow thse steps.
Belkin router blinking orange FIX belkin router amber light Issue
This may help you.
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
"wired" light
the wired lights only comes on when there is a Ethernet cable plugged in to a port, each light has its corresponding light Eg. port 1 Light 1.
unless there is a wired connection between a computer, game console, or anything else that you might have that requirres a internet connection the light will not light up, its normal. Note : light does not come on if you are connected wirelessly
Mar 05, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
The lights are on but the linksys is not working
Certainly if the conection directly from the router to the computer is not working then the wireless won't work. So that's where I'd start. Cable connections could be an issue. The connection without the router works I assume. Make sure you are connected correctly. You need ethernet cabling to the ethernet, networking connections to and from the internet device to the computer and into and out of the router. When you get the direct router connections working you can solve your wireless problems.
Sep 24, 2008 | Linksys Wireless-G WRT54G Router
Connection dropping
If the lights are flashing - that's OK. Wireless light will flash because the connections and beacon transmission, port lights will flash because of local connections. We can troubleshoot this for a while but I think this might be a problem with the box. Probably the best option is to replace it. In case you would like to play, try to run Ethereal and capture the packets and analyse them.
Jun 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
NetGear DG834G Wireless Router Logo
373 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
