Question about Honda Garden
No pressure i want to get the physical drawing for repair Thanks
Have grundfos jp4 with controller. it will start up in the night when no taps turned on,? and to me it appears to have less pressure when using the hose? is there a pressure adjustment
No pressure adjustment.
Air bubbles in line will decrease pressure... air vent at highest point can help solve problem.
http://waterheatertimer.org/Repair-water-heater-valve.html#air
Possible leak problem on Hot line somewhere, and/or pressure problem.
Turn off all taps and check before and after result on water meter.
If toilet is running it draws cold water... but if you have bad single-handle faucet cartridge, it can draw hot into the line.
Following links have troubleshoot resources:
http://waterheatertimer.org/Low-water-pressure.html
http://waterheatertimer.org/Crossover.html
Oct 21, 2017 | Grundfos Plumbing
Eternal GU-195S Hybrid water heater
Is this new installation? Or old installation that stopped working?
Here's the 100% solution. And it applies to all brands, models, types, of tankless water heater, no matter which error code:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
People should avoid complicated water heaters that claim 'energy star' and '98% efficiency' while proclaiming 'endless hot water' as if the laws of physics, economics and common sense can suddenly be suspended if only the customer would buy expensive, complicated water heater that cannot be maintained or repaired by customer, and there are no qualified technicians who live in your area.
Otherwise you need a service manual, or contact eternal manufacturer. 1-866-946-1096
http://eternalwaterheater.com/pdf/downloads/GU100.pdf
Error E02 does not show in manual.
E2 is ignition failure, which on other brands can be failed PC board... and inadequate incoming air supply, or venting, or failed sensor, dirty combustion parts, air or water in gas line, low gas pressure, wrong gas, etc, or multiples from list above.
May 09, 2013 | Water Heaters
How to draw in microsoft word
Using Microsoft Word for drawing is not recommended. If you are interested in a simple drawing program, use Paint instead. There are also many -free- advanced drawing programs such as GIMP which may suit your needs better.
Nov 28, 2012 | Sony The Cartoon Guide to Physics...
Detergent tank will not draw.
Detergent tanks will only draw at low pressure. Switching to low-pressure is done is several different ways with different makes/models. Some pressure nozzles are push/pull, some are twist and some just have a quick coupling and you have to keep up with a low pressure tip (usually colored black).
If it will not draw at low presser, it is either stopped up with debres, or the check ball inside the injector is stuck. The injector is the little device that is just before the outlet where the pressure hose hooks up. These always have a small metal ball, held in place with a tiny spring. This ball is there to prevent pressurized water from shooting back into the detergent tank. The ball and seat that it presses against can get stuck together with old detergent residues, calcified deposits from the water or even rust.
Use a small crescent wrench to take it apart -- or if you prefer, find the right size box end/open end (metric) wrench. Be very cautious as it comes apart because that little spring can leap out and they are hard to find.
I hope this is helpful to you. If it is, please take a sec to rate me. Thanks!
Don
Mar 10, 2012 | Karcher K 391m Pressure Washer
My washer will start but only run for a few seconds......unless you hold the primer bulb in
The primer bulb has a pin hole in it:
This is what you need:
http://www.mymowerparts.com/partdetail/1079/14606.php
All local lawn mower repair / parts sources have this part in stock. This is a common issue with primer bulbs that you have to hold the bulb in so that it will run. When you do that your stopping it from drawing air through the hole in the primer bulb so it operates normally. Replace the primer bulb and it will be fine.
Thanks for choosing FixYa,
Kelly.
Aug 14, 2011 | Briggs & Stratton Gas Pressure Washer...
Do I need only one cord (usb) to connect to my laptop?
The "physically-smaller" external hard-drives draw power through the USB cable.
The "physically-larger" external hard-drives require an external power-supply (just like a laptop requires an external power-supply).
Check the casing for a plug where the electrical power would come in; if none, then the unit will draw electrical power through the USB cable.
May 31, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Repairing front drivers side door on a 1995 suzuki sidekick
Haynes and Chilton repair manuals are very good for body repair ie: taking apart doors and the electrical and physical challenges you can expect to encounter.
Jan 27, 2009 | 1995 Suzuki Sidekick
Garden Logo
75 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
