Question about Whirlpool Duet GHW9150P Front Load Washer
Cnt get door unlocked on washer
Cant get door unlocked on washer
    Genius:
  • Whirlpool Master
  • 1,474 Answers
If water is in machine drop drain hose to floor level to drain off door should now open..good luck
Posted on Sep 29, 2009
I have model gx5fhdxvq the tempratur in frezzing area fronm -16to -24 i cnt change more
hi.cant understand your problem .going to assume u mean u cant change the temperature or choose.sounds like control panel pcb board faulty.good luck Ali
Jun 27, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hi. My washer is coding dU then F as codes.. I cant get it to shut off and unlock the door to get cloths out. The book does not have a code for dU.. PLEASE SOMEBODY HELP ME :)
Door unlock error. The machine tried 6 times to unlock the door. Must be an item of clothing jamming the door. take the bottom panel off and reach up and grab the emergency ring, GENTLY release the door amigo. Use this GUIDE for repairs
and use your tech sheet inside that base panel for error codes and diagnostics.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer door wont unlock. tired leaving off. cant open door
check the wax motor, if it's working, or there could be problem with the springs on the wax motor.
Aug 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer is stuck
try unplugging it for about 10 minutes and then plug it back in and see if the error dosent correct itself.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag neptune too much water, will not drain, door won't unlock
you may have something stuck in the pump a sock or a dish towel something small. you will have to get to the pump,,,thats why it wont drain or spin out it cant.
Jan 22, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore front loading washer
brand new and you changed the latch mech.? door latch or lock asm.? DU is door unlock error, it tried to unlock and cant. usually replace lock asm (inside machine) for this problem. may have latch out of alignment.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Unlock codes for samsung sgh-j750
power up with none account then put the code *2767*3855# then enjoy..,dont worry if u cnt c z charactor u r puting its obvious and works perfectly
Nov 20, 2008 | Cell Phones
Door lock
try crc into lock
if no good replace door lock
Nov 16, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front load washer
LO means bad door lock switch or conrtol board. to get it open unlock manually by pulling plastic cable located in dispenser where soap is put in.
Oct 29, 2007 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
