Question about Whirlpool LEN2000PW Dryer
My dryer stopped heating up so I tried to fix the heating element. I noticed in the other one that some of the coiles broke in half so I knew this was the problem. Well I bought a new one, hooked it up and ran the dryer. It worked for about 30 seconds with heat coming out and the coils glowing but then it started to spark. Do you think I hooked it up wrong, maybe a defective element, or could there be something else wring with my dryer?? It is a whirlpool electric model len2000pw0
  • Whirlpool Master
  • 7,482 Answers
Could be a defective element, but it also could be your thermostats faulty...give them a check.
Normally you can only hook up the heating coils one way...I do not believe that would be the problem.
Hope this helps
Posted on Sep 29, 2009
How do i fix a duet dryer that takes too long to dry
I pulled apart the back of my dryer to access the heating element. I noticed I have a break in one of the coils. So, that means I need to buy a new one. The thing I noticed is that only of of the terminals at the bottom of the heating element has a plug on it. There are no additional wires inside the dryer that could have come off so I am a little confused as to if i new coil will work.
I watched a video online and it clear shows both terminals being connected. Anyone have any advice?
Feb 20, 2012 | Whirlpool Duet 3.8 cu. ft. Front Load...
Our Kenmore elite dryer has no heat, what do I do?
The First thing I would do is look at the heating element, you must unplug the dryer and remove the screwsfrom the back of the dryer and then locate the element and inspect it for being broke, if any of the coil of the element is broken you must order a new element.
Jul 18, 2011 | Kenmore Elite HE4 Electric Dryer
Heating element. How about just replacing the coil?
you can get a re-string kit if its the open type heating element round pan style and re-string it yourself for about $30-$40
May 27, 2010 | Dryers
Electric dryer won't heat, maybe the heating element but before it stopped heating i cleaned the lint trap and something fell into it and i didn't notice and turned it on and could hear it hiting...
Sounds like you broke the heating element. Go to a local shop and get one. You may have also burnt the timer so after element you may need a new timer as it tells it to put power to it.
Jul 08, 2009 | Whirlpool LER4634J Electric Dryer
Drying is not heating up.
try replacing thermal fuse. its cheaper than the heater element. this fuse blows when there is restricted air flow over the heating element. meaning clogged vent. you can ohm out this fuse. fuse is located at top left of heater duct with two wire leads going towards it. if its ok then remove heating element and look at coils. usually you can see one broke
Jun 24, 2009 | KitchenAid KGYS850LT Gas Dryer
Heating element only turns red when dryer door is open
You are correct you do have a dead short on the element.You need to replace the element.Hope i fixya :)
May 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Electric dryer...turns on, runs...no heat
heating element is bad unplug machine access the heating element it should have a break in the coil if so twist the coil back together gently though put it back in and try it i didi it to minr 6 years ago and no problems and you save a ton of money.
Mar 16, 2009 | Dryers
Wirlpool dryer heating poorly
Make sure you have got it set to full heat and not half heat, you may have a faulty heat selector switch.
Dec 09, 2008 | Dryers
MAYTAG Heat Element Shield?
not really put the plate back on it helps force the air across and keeps lint out
Jan 30, 2008 | Maytag PYE2300AY Electric Dryer
Whirlpool LEN2000PW Dryer Logo
304 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
