Hi, White dots are due to bad DMD chip and qualified tv tech can replace required DMD chip in this tv to fix the picture issue. Please contact nearest Samsung service center or local tv repair shop for repair estimate. Thanks.
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Mastersage!
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Sony wega blue dot or star pattern on screen http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655 Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620 Sony LCD Rear Projection TV - Optical Block Problems http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock
the color drive is going bad check with the sony service center it might be cover and repaired free. my set went blue and the service tech is checking if it is covered. good luck.
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
