Question about Car Audio & Video
I have a 1963 seeburg jukebox. the motor runs and turntable goes around normally. but it wont pick up the record. i think its the cam. help thanks
    Problem Solver:
  • 16 Answers
Your Seeburg LPC1 or LPC480 is well overdue for an electrical overhaul.
It most likely can no longer write selections into the memory, or read them out if they're being written in. No way to tell from here. A jukebox that old probably needs to have the units underneath rebuilt with new capacitors. Their lifespan is usually about 25 years, so no surprises there. This is common for all old jukeboxes. Google Vern Tisdale or Bill Bickers for the rebuild kits. You need to solder and read a schematic to do the work, or find someone who can, but the actual parts are not all that expensive.
Posted on Feb 28, 2010
Seeburg 1960 AQ 160 Jukebox. The mechanism very hard to turn even with finger. Turntable not turning with lube added.
Rotate by hand till shaft actually receives lubricant especially if you did not remove the turntable to apply the lube 1960 model all oil dried up contaminated with dust of 57 years
Apr 25, 2017 | The Audio Players & Recorders
I have a 1963 Seeburg jukebox that won't play the b side of the records. How do I fix it?
Not likely you will get a good answer from the sewing machine category.
Feb 05, 2017 | Sewing Machines
I have a LPC 480 Seeburg Jukebox that scans, pick up the record, the needle touches the record, then returns the record to the carriage without playing. What can I do?
Try reading this, basically the fault can be in the mech, the amp or trip switches.
http://www.flippers.com/Seeburg-trblshoot.html
Nov 28, 2010 | Audio Players & Recorders
Can weak tube be cause of jukebox not picking up records
1> be sure the service switch is in the PLAY position.
2> It's impossible to determine if the selections are not being written in to memory, or read out from the memory. it could be either.
You most likely have to have the control center looked at, common with a machine this old. The capacitors in your control unit on the back door have probably gone bad, which they do after 25-40 years. Your jukebox is from 1960, so it's time to have both the amplifier and control unit rebuilt. Not what you wanted to hear, but it has to be done. If you're handy and can solder and read a schematic, you can buy the kits on eBay or do a Google search for Bill Bickers or Vern Tisdale. Both sell the rebuild kits.(Feb 27, 2010)
Jan 24, 2010 | Numark TTX Turntable
Seeburg jukebox sx 100 scans twice and returns
I suggest that you go to the following site for a solution to your problem.
The information listed hereis second to none.
http://home.pacbell.net/fmillera/
Regards
Alan Hood
ami-man
UK
Oct 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
Juke box (seeburg 480 serieswill take coins but won't play record
YOU ARE SAYING THE MOTOR DOES NOT SPIN. TRY TO SPIN THE DRIVE SHAFT ON TOP OF MOTOR . DOES THE SHAFT TURN EASY. IF NO THEN YOU HAVE A MOTOR OR LUBRICATION.
PROBLEM.
DOES THE SCAN SWITCH, WHEN PUSHED TO SCAN DOES IT SCAN. IF IT SCANS BACK, AND FORTH 2 TIMES, YOU THEN HAVE A COIN CREDIT PROBLEM (MOST LIKELY )
ANSWER THE TWO QUESTION, OR STATEMENT. TO GET A MORE INTELLIGENT REPLY.
YOU HAVE OVER 2000 PARTS IN THAT MACHINE. YOU HAVE GIVEN A (WHY DONT IT WORK
QUESTION.)( there is no answer to the question. because of limited problem info)
DOCTOR FIX
IN-HOME JUKEBOX REPAIR
6362273300
May 09, 2009 | Audio Players & Recorders
Wailing sound when 1971 seeburg juke box is started
I amnot very familiar with Seeburgs but the trip switch activates at the end of the record playing and THAT mutes the amp. The amp should also be muted until the tone arm lands on the record. So I would suggest the problem is in the amp.
May 05, 2009 | Audio Players & Recorders
Mechanism will not pick up records
Check out the tormat on your jukebox. It runs almost the full length of the mechanism. On the tormat is the A and B side contacts and a ground rail. You will see that on the mechanism is a arm that runs over these contacts on it it has very fine wire links (similar to those on motor brushes) these can become disconnected and may require being resolderd back into place.
Regards
Alan Hood
ami-man
UK
Jan 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
I have a 1972 Seeburg that misses plays, rejects plays before they are done and will go all the way to the right and thinks it has picked up a record and get stuck there. Thanks in advance! David
Possible causes.
_Black and gray box connections are probably dirty.
_Keypad circuit board dirty (yes, this makes the jukebox make incorrect selections)
_Mis-adjusted end-of-record switch.
_In addition, a manual would help so you can go over the adjustments section to check all those and then, on top of everything else, it probably needs a lube job.
Seeburgs are the most complicated of the 45 jukes, so it might be time to call in a professional if you're not comfortable tinkering.
You can screw one up pretty bad if you aren't familiar with them.
Jul 02, 2008 | Audio Players & Recorders
Car Audio & Video Logo
696 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
