I have a sansui g801 pure power DC stereo receiver and the volume switch works intermittently. It has been cleaned which made it a little better but it still keeps going off. Is it the switch or the electrics? Where can I get a spare part?
Did you get your G-801 fixed?
Posted on Nov 28, 2009
My sansui g4700 pure power DC receiver all of the sudden started popping tube fuses... Why???
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 17, 2015 | Sansui Audio Players & Recorders
I have an older (10 ) years Sansui am/fm receiver model rz-5500av. It performs well, but after a power surge, the fm radio will not play in stereo. The fm stereo indicator flashes on and off. I was told...
Part of the circuit is a stereo multiplexer decoder, that decodes the fm stereo signal, I guess that is what you mean when you talk about capacitor linked to the fm band.
I do not have the sbchematics for this circuit, if you are good at electonics just grab the tester and check the whole circuit. On a radio is not difficult to find a blown capacitor.
Test also the stereo/mono switch.
Sep 21, 2008 | Sansui Audio Players & Recorders
I have a Sansui 2000A Stereo Tuner Amplifies that powers up but has no sound. the fuse for the 220-250V 2A was blown and replaced. The speaker fuses look good. Should I replace them too or is there...
If the fuse was blown on the 220-250 V side, I am assuming that you are in the UK, if you aren't , but are in the US, change the power setting dial/switch on the back to 100-120v and you might be good to go. Also, I know this may sound silly, but make sure that the speaker selector switch is pressed in or set to a speaker set ( A or B). Love the Sansui gear, have many complete systems myself!
Oct 17, 2013 | Sansui Classic Vintage 2000a Stereo...
I have a Sansui G-4700 Pure Power DC Stereo Receiver. We were happy with it for many years. Five years ago, we moved from a house to a condo, and it has been in storage since the move. I am thinking of...
Of course it will work with any standard stereo RCA source (which just about everything STILL has) but it won't work directly with any digital sources. It has NO digital interfaces.
Jun 22, 2011 | Sansui Audio Players & Recorders
I have a sansui G9700 receiver/amp. The volume control works intermitantly. Must play with it to get volume. I believe I need to replace the potentiometer F3085. where can I get one? Erick G
The potentiometer doesn't need to be replace, it has collected dust inside causing the intermittent operation. Buy a contact cleaner/conditioner to spray inside it and move the potentiometer clockwise and counter clockwise a few times until the dust inside it is gone.
Check this link to find a contact/conditioner cleaner or you can try spraying rubbing alcohol but this could because alcohol doesn't not lubricants properties.
Let me know if you require further assistance.
Nov 27, 2010 | Sansui Audio Players & Recorders
Hi I have a JVC KD-G801 car cd player/radio. Today a mechanic uninstalled it from a car I have which I will be selling and he installed into a newer Peugeot 306 I bought at the weekend. The stereo is...
Yes... the wire designated for constant power which powers the clock and some of the lessor memory functions is disconnected.
I would remove the radio and look for the lead that is disconnected and have a constant power lead attached to it to cure this issue.
Have the mechanic who did it the first time do it.. as it was already paid for him to do so in the first place...
Oct 06, 2010 | JVC KD-G801 CD Player
Stereo Amplifier fades out. My Sansui dolby pro
No that's how to describe a problem, folks - with details. Using internal FM as the source is always the preferred way of troubleshooting system-wide receiver audio problems (no cables or setting in the way).
Does the sound come on immediately with power and then fade or is there a small delay while the electronics stabilize, a click and then sound that fades?
The fizzle probably means something is rapidly overheating or a capacitor is malfunctioning. If both channels do it, I'd suspect a common power supply problem. Can't help much more than that.
Dec 12, 2009 | Audio Players & Recorders
I need a replacement volume control for a Sansui-AU-717.
Hi p00pmeister
This great old amp uses an Alps brand attenuator. This could be a little hard to find an exact fit replacemernt. Have you tried to clean the control. The can generally be restored by flooding the internals with CRC 2-26. If you have intermittent channels, check also the amp/preamp switch to the rear of the amp also.
Check out this Has some instruction on dealing with the disassembly of the attenuator
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 05, 2008 | Sansui Audio Players & Recorders
I need a power switch for a Sansui 5000a Part number MSH501X, 125V, 3 Amp
hello
not to sure if any help but you could try here or email them see if they can locate one for you, Vintage Sansui stereo parts & salvage units for receivers.
riz.
Mar 20, 2008 | Audio Players & Recorders
How to fix
Temporarily unsolder/remove vol up/down tactil switches on front of circuit board.They may be sending unwanted signals to the microprocessor. Does set work normally now? 2)Try removing batts from remote.3)PVAT! Pull chassis, Solder any/all bad connects esp. regulator pins.4)Send in to shop for diagnosis.
Oct 01, 2007 | Sansui DTV2760 27" TV
362 people viewed this question
 Grubhead
Grubhead
