Question about Asrock 775i65GV Motherboard
Help when i insert the memory in the first slot it cause unexpected display and hung the computer.. when i insert in the second slot it open my windows but after a second it shut down and shutdown again then no display.. i try this memory in another computer and it function normal... what is the problem the? is this the memory slot?
    Genius:
  • 1,601 Answers
Sounds like it the wrong type.
Posted on Dec 19, 2007
The camera beeps when we put the card in.
The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
To insert the memory card:
1. Make sure the lens cover is closed (the power is off).
2. Open the memory compartment on the side of the camera.
3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
4. Close the memory compartment cover.
If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted.
Mar 13, 2011 | Polaroid PhotoMax PDC 640 Digital Camera
Unsupported memory configuration.please populate dimm1
open it up ..and see what is wrong with the first slot of ram memory ...if the inserted module is not working ...than remove it ..(to check if it works just leave it by itself and try to start the computer ..) anyway ..if there isn't any module in the first slot ..than move one from the last slot ..I mean mount the modules in slots from number 1 to ...as many you have available ...After finish ...restart ..press delete button right the way to go to bios settings ...and in here ..look for optimal factory default settings ..and engage them by selecting with arrows..and enter..and confirm with enter (Y)
to save settings before exit ..press F 10 ..and enter ..
This will assure the ram configuration ...in the correct way ..
Please read careful ..and ask if you do not understand something ...and also ..please rate my answer..cause it helps with my rating and activity on the site..
Feb 14, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
How to upload photo
Transferring images from a Memory Card to a Windows Computer Follow the steps below to transfer images from a memory card to a computer running Windows. Step one: Insert the memory card Follow the steps below to insert the memory card into the HP All-in-One.
  1. Turn the memory card so that the label faces left, and the contacts are facing your HP All-in-One.
  2. Insert the memory card into the appropriate slot on the HP All-in-One.
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass-storage port on your HP All-in-One. These read-only partitions are added by the drive manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive. When the memory card is inserted correctly, the Photo light next to the memory card slots begins to blink. The message Reading... appears on the color graphics display. The status light next to the memory card slots blinks green when the card is being accessed. If a memory card is inserted incorrectly, the status light next to the memory card slots blinks amber and the color graphics display shows an error message such as Card is in backwards or Card is not fully inserted. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. Safely remove a card only when the status light next to the slots is not blinking.
Step two: Transfer images without using the HP Photosmart software After inserting the memory card into the HP All-in-One, the memory card appears as a drive on the computer. Follow the steps below to transfer the images on the memory card to the computer.
  1. Press the Photo button to display the Photo menu.
  2. Press the down arrow button (c01133817.jpg ) to select Transfer to computer .
  3. Follow the prompts on the computer to complete the transfer of images.
    NOTE: If there are photo files on the memory card that have never been transferred before, a dialog box on the computer asks whether you want to save the photo files to the computer. Click the Transfer option and all the new photos from the memory card are saved to the computer.By default, the image files are saved in month and year folders depending on when the photos were taken. The folders are created under the C:\Documents and Settings\username\My Documents\My Pictures folder.
Dec 08, 2010 | HP Photosmart 3210 Printer
No video output. bleeping every 7 seconds
This beeping is usually caused by a bad Memory or Ram chip. The memory is the chip that is inserted in the purple slots in your display picture. Remove them if there is more than one and replace one by one. Make sure they are firmly reseated or it could damage the motherboard. Make sure both clips on either side are fastened properly.
Try booting computer again. If it continues beeping the memory module may be bad. Replace it with a new one.
Thanks and good luck!
Lolita
Jan 18, 2010 | Chips M863G V1.5 Motherboard
I have the same problem 6 beeps...I green 3 yellow lights
That beep code indicates memory is not being properly identified or used. Try removing memory and testing with one module at a time until you find the one module or slot that is causing the trouble.
Jun 26, 2009 | Dell Dimension 4700 PC Desktop
Upgrading the RAM. Can't find where to put it.
The computer has two memory expansion slots—Slot A and
Slot B. You can install one or two memory modules.
1 Shut down your computer completely using the Shut Down
command.
2 Unplug the computer.
CAUTION: Installing a memory module with the computer’s
power on may damage the computer, the module, or both.
3 Close the display panel and remove any cables you may have
connected.
4 Turn the computer upside down.
5 Locate and remove the screws that hold the cover plate in
place, then remove the cover from the bay.
Removing the memory module cover
CAUTION: Static electricity can damage the memory module.
Before you handle the module, touch a grounded metal
surface to discharge any static electricity you may have built
up.
To avoid damaging the memory module, be careful not to
touch its pin connector on the side you insert into the
computer.
6 Remove the new memory module from its antistatic
packaging.
7 Insert the memory module in the slot and gently press it down
into place.
The clips on either side of the module will click to secure the
module.
Inserting the memory module into the slot
8 Replace the cover plate and the screws.
9 Turn the computer over and restart it.
When you turn on the computer, it automatically recognizes
the additional memory.
Removing a memory module
If you need to remove a memory module:
1 Complete steps 1–6 in “Installing a memory module” to shut
down the computer and open the memory module cover.
2 Pull the clips away from the memory module.
The memory module pops partially out of the slot.
Adding memory
Pulling the clips away from the memory module
3 Carefully remove the module from the slot.
4 Replace the cover plate and screws.
May 15, 2009 | Toshiba Satellite Pro 6100 Notebook
My mother board is not runing
Turn the computer off and disconnect the power cord. Open the case and remove the RAM. You need to install the RAM in the same slots that it was in before you removed it yesterday. There is a retainer at each end of each slot. Push those down and away from the RAM to release the memory. Depending on the memory, there will bee one or two indexing slots in the contact edge. There will be corresponding indexing ridges in the memory slots. Align the slots in the memory with the ridges in slots of the mother board and insert the memory. Make sure that the retainers close fully when the memory snaps into the slot. Close the case and connect the power cord. Turn the computer back on and it should boot normally.
Good Luck, and please let me kow how it works out for you.
~ Spoem
Mar 25, 2009 | Intel Motherboard
Dell Inspiron 600m not starting up!
I had this same problem with my 600m laptop.  How many times do the lights flash, before they stop flashing?
Cause: There is a physical problem with the computer that it is detecting at startup diagnostics.
Solution:
You should have two pieces of RAM installed. Carefully, remove the memory slot cover.  Swap the 2 pieces of memory you have in there (please follow memory installation and removal for laptops to the letter, by never touching any of the electronic contacts and handling the memory from its sides). Make sure, they sit in the slot properly (to the best you can see). Then, place back the memory cover, very carefully, and screw in.  If you see the memory door cover not closing properly, the RAM might be improperly inserted.  Please go back to the swapping of RAM step. :)
If this didn't work, 1 of the 2 RAM's you have are no longer functioning properly. Please follow the steps to openning the memory door again and remove RAM in "B" slot first.  Then close it and try to start the computer.
If it still doing the same light flashes, open the memory door and remove RAM in slot "A".  then place the RAM you removed from slot "B" into slot "A".  Then start the computer again.
Jan 02, 2009 | Dell Inspiron 600M Notebook
Display standby
it must be the memory or the RAM. try to remove it and insert it on the other slot. if still happening the same problem then try to use windows xp service pack 2 (thats what im using right now). format it again. hope that helps!
CHARCOIS
Sep 13, 2008 | Intel Motherboard
Gateway sb-4100-b won't recognize new memory
Check the owners manual of your computer for the correct installation of 2 sticks of memory, this can be critical on computers with 2 banks of 2 slots, it will also tell you the maximum ram that will work. If you do not have the manual, go to the manufactures website and then go to the support link, and browse for memory installation. BPCS
Dec 28, 2007 | Gateway Sb-4100-A PC Desktop
Asrock 775i65GV Motherboard Logo
47 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
