Cold water will not stop running once bowl is full and hot water stops?
    Top Expert:
  • Washing Mach... Master
  • 76,848 Answers
The cold water valve is defective
Posted on Sep 29, 2009
How can you get a washer smelling good?
First of all this mainly happens when you use cold water washing, the plastic bowl(s) become slightly porous over time & the dirt from clothes adhere to the area between the inner & outer bowls.
To clean & remove smell.
1. Put washer on hot wash, high level & let it fill with HOT water.
2. Stop washer, put in an old towel.
3. Add a bucket of hot water (This allows the water level to be above the scum mark inside machine.
4. Add washing soda to the bowl (double the amount it says on the packet).
5. Start washer & allow to run to the end of the first wash cycle.
6. Stop washer & allow to sit for a few hours.
7. After the few hours, start washer & allow it to run the rest of the full cycle.
you can do the same procedure with Vinegar.
you may have to repeat procedure a few times.
TO PREVENT THIS FROM HAPPENING AGAIN YOU NEED TO DO THIS PROCEDURE ONCE EVERY 3 MONTHS.
The worst case scenario, you will have get a technician to remove the inner bowl & manually clean these areas.
Apr 27, 2014 | Haier HLP21E Top Load Washer
How do i put water in my radiator?
you need to replace thermostat and radiator cap.look under hood around engine compartment.look for a radiator cap near radiator,add 50/50 antifreeze and water to coolant system to bring up boiling point.pure water will cause engine run hotter because water evaporate away,remove radiator pour coolant in the radiator until coolant stop dropping in the radiator now some vechicle pour coolant in the coolant overflow jug,pour coolant until coolant level stop dropping and the coolant level stay at cold full mark.start engie let idle few minutes, watch coolant level in radiator if coolant start dropping add more coolant, when coolant level stop dropping put radiator cap back on let engine idle until both top radaitor hose and bottom coolant hose get warm turn off engine wait until it get cool then take a large rag slightly open radiator just a litle at a time to keep from getting scaled.once radiator remove add more coolant if low,put radiator cap back on start the engine let it idle watch the temp gauge if temperature gauge going hot zone stop engine wait until cool then add more coolant,keep doing this until engine stop overheating going into hot zone and coolant level stop dropping,make the coolant overflow jug coolant level stay at full cold mark, dont let jug run empty if so air will get in the coolant system causing engine to overheat.
Jul 22, 2012 | 2000 Plymouth Breeze
Water is leaking out the top it appers that the
Hi just read your posting.When you say the water is leaking out of the top ,does that mean it is leaking on the floor or leaking into the bowl even when the machine is off.If it is leaking into the bowl then it is a faulty water valve.Turn off the cold tap and leave for an hour and see if the water stops and if it does stop then the problem is the cold valve.If it doesn"t stop the leak turn the hot off and leave for an hour and see if that stops the leak.By memory I think your water valves are a double unit and to change one you must change both.Please reply with additional information about where the water is leaking to and I can help you rectify this fault,
Jun 16, 2010 | Fisher Paykel EcoSmart GWL15
How to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Feb 10, 2010 | American Standard Bath Faucet Ceramix...
Washer filled up for the rinse cycle then stopped won't do anything now. checked the outlet and have power there. Washer still full of water.
first of all you need to empty this washer by pulling the drainage pipe out of the waste pipe at the back then place a bowl on the floor and place the pipe into the bowl until all the water stops,when bowl gets to full then lift pipe higher than the washer to stop water coming out,once empty renew the carbon bushes on the motor as this will be the problem.
Jul 06, 2009 | Washing Machines
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Whirlpool Wahser top loader
possibly cold water should be running into the tub at the same time as the cold to regulate the temp.by only having the hot on, it could possibly have timed out and while still being short of water
Jul 08, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
