Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
3 green spots on the top center of my projection hd tv
There's 3 green spots on the top center of my screen of my projection hd tv
when I turn the tv on is there ,when the colors of the picture are dark you
can't see them,but when the picture has light colrs like light blue or white
you can see them ,like 3 green suns is there a solution please help me
  • 4 Answers
I had a similar problem and brought it in to a technician for a quote of $860 to fix. The problem - speck of dust on the optics. If it weren't under warranty I would take it apart and blow off the dust myself.
Posted on Dec 24, 2007
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Green spots some permanent some gone when tv comes
for some of these models there is a software patch that will correct this problem. contact panasonic authorized service center they may have the equipment needed to perform the software upgrade
Feb 06, 2010 | Panasonic PT-52LCX65 44" HDTV
Yellow-green spot in center of screen
Defective light engine. Contact Sony support. They warrantied a lot of these sets even after the warranty had expired because of so many going bad after 3-4 yrs. Have the complete model and serial number ready when you call them.
May 20, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic 52LCX65\PT Green Spot
COLOR CONVERSION IN THE MENU ,,TRY THAT,,IF NOT A NEW CABLE,,CONVERSION REALIGNS THE COLOR
Apr 17, 2009 | Panasonic PT-52LCX65 44" HDTV
JVC 52 in rear projection TV
i would call a repairman out and have it fixed..it would be alot cheaper than buying a new tv.
Jan 24, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Green and purple spots on my screen.
This unit requires the EEPROM correction tool Part # LSUQ0100.Only an authorized Panasonic service center will have this tool.
Jan 14, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Light green and pink spots on my hd tv!!!
Hi--Bought my panasonic pt-52lcx65 on sale for $2200 in 8/05. Replaced the lamp for about $300 in 1/08, just prior to Superbowl. Admittedly, this was to be expected after family members watched lots of tv over 30 months. However, two months later the blue spot emerged in 3/08, and red spot emerged 5/08. Set looks decorated by a Andy Warhol or Van Gogh wannabe. I'm looking for a fix it solution. Dr. Bob Heiliger, Lebanon, OH.
Jun 08, 2008 | Panasonic PT-52LCX65 44" HDTV
Green spots
Good Day;
It sounds like the TV has foreign objects on the tubes, lenses or inner-screen, such as dust or bugs.l Remove screen from the front and observe.
If it were a TV problem the spots would be near the center of the picture.
Good Luck.
Jun 07, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
136 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
