Question about Sharp Office Equipment & Supplies
Change the ip address on a sharp copier 92755
  • broncomann7 Oct 13, 2009
    problm been fix I got it done
  • Josh Firster
    Josh Firster May 11, 2010
    Need to know the exact model number before I can assist you with this.
  • 63 Answers
If this is a Sharp copier then you can go to either custom settings or system settings. Log in as administrator, find the settings under printer settings-NIC or NIC will have its own tab.
Posted on Oct 13, 2009
CE-00 error code when scanning to an IP address. Scans to e-mail address just fine. Have two machines, works on one machine but not the other.
When you say scanning to an IP address do you mean like Sharpdesk? Usually it means an IP address has changed.
Nov 08, 2011 | Sharp MX-M350 All-In-One Printer
Scanner user IP address changes
Print a configuration page and enter the machine IP in the address box. That will pull up the machine settings then most likely look in properties and go to what you want to change.
Jul 29, 2010 | Sharp MX-2300N Color Copier
Scanner doesn't send to PC
hi
I dont work on Sharp machines but this may help
If a PC or network is running DHCP it means the IP addresses are on a short lease and are called Dynamic IP addresses.
If DHCP is turned off then your PC's are running Static IP addresses which means that they will not change.
Ok...if you are running dynamic IP addresses your scan to PC destination will have to be the host name of your PC and not an IP address
eg   james.
to find out, do the following
start,contol panel,system,computer name.
hope this helps
Aug 13, 2009 | Sharp Office Equipment & Supplies
How do i change the IP address on the sharp ar 275 copier?
press printer button >special key then you can browse through arrow button check there you can see how to change IP address
Jul 19, 2009 | Sharp AR-275 Copier
I can't change the printer IP Sharp AR-BC320
If you know the IP address, connect the printer with a laptop using a cross cable. Go to the printer web page by typing the IP address of the machine in the Internet explorer. Browse the menu under network setting and save after you change the gateway
Dec 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
Dont know ip for my Sharp AR_C270 i just bought
Find out what the gateway setting are on your computer and assign an ip address based on the gateway.
For example if your gateway is 192.168.0.1  then a good ip address would be 192.168.0.XXX.  xxx=available ip address to use.
Your copier does have a DHCP setting that allows the router to assign on automatically for you if the copier is connected to one but you should assign that ip address manually after using DHCP because if the power goes out, it could assign a different one than the previous assignment making the IP port assignments to print with on your computer useless without creating a new port.
Oct 19, 2008 | Sharp AR-C270 Color Copier
IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP.  That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier.  If you can get a control panel screen of the copier to appear.  It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
Oct 16, 2008 | Sharp AR-C270 Color Copier
NO IP ADDRESS FOR THE AR-C270 sharp copier!!!!?
Custom settings, List print, Print test page, NIC Page.
Dec 15, 2006 | Sharp AR-C270 Color Copier
246 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
