Question about Olympus EVOLT E-500 Digital Camera
My olympus evolt E-500 camera was working fine but battery was low, put in fully charged battery and camera wouldn't turn on. got home and took battery out of charger(green light was on charger)put in in camera and it still wouldn't turn on, any ideas what the problem is?
    President:
  • 1,723 Answers
Clean off the contacts where the battery makes contact with camera contacts. Use a pencil eraser of a match book striker (for the sandpaper). Make sure the battery is seated tightly against the contacts. If it's not tight, use a piece of the cover from the match book for a small 'shim' to hold the battery tight.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 29, 2009
Is lexar 16GB SD card compatible with olympus evolt e500
It should work in the Olympus. Insert the SD card then power up the camera and go to the Menu setting and format the SD memory card.
May 27, 2012 | Olympus EVOLT E-500 Digital Camera
How do I switch the lens on my Olympus evolt e500
1. Switch off the camera
2. Prepare the lens you want to put on
3. Remove the rear lens cap by turning it anticlockwise
4. Put the camera in your left hand's palm so you can press the lens release knob wit the finger, and press it down.
5. rotate the lens anticlockwise, and remove it
6. immediately put another lens on the camera. The both red dots, on the camera and the lens must be aligned
7. Rotate the lens clockwise.
8. Put the rear protectiv cap on the lens you just removed.
9. Now yuo can turn the camera on and take the photos.
May 02, 2011 | Olympus EVOLT E-500 Digital Camera
MY OLYPUS E-500 SAYS CARD ERROE WHEN I TURN ON MY
Did you try to format the card using the camera's software or your computer?
May 20, 2010 | Olympus EVOLT E-500 Digital Camera
Camera or battery problem?
Sounds like a battery problem. When a rechargeable battery is allowed to completely discharge from non-use, it usually will not come back.
Dec 15, 2009 | Olympus EVOLT E-510 Body Only Digital...
Olympus evolt 500 - Flash won't pop up
did you have the auto pop up in the menu on?
Jun 20, 2009 | Olympus EVOLT E-500 Digital Camera
My e-500 goes completely dead when shutter is depressed. battery must be reloaded to power on. all other features works fine.
reset the camera back to default using the menu... (custom reset and camera needs to be in P,s,a, or M for reset to work) else it is repair
Mar 26, 2009 | Olympus EVOLT E-500 Digital Camera
Olympus E-300 Evolt - LCD Screen doesn't come & SSWF light stays on
My camera is working again, but the problem is not completely solved. What I did was to put on the old lens, take out the battery then turn on the camera and finally put on the battery again. And now it works. But the problem with the new lens (Zuiko digital 40-150) continues.
Jun 30, 2008 | Olympus EVOLT E-300 Digital Camera
Battery charger for Olympus E-500 camera
dear cienkusmike,
This charger should work to charge the battery that came with the olympus E-500.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 08, 2008 | Olympus EVOLT E-500 Digital Camera
EVOLT E-500 LCD Problem (Mirror Image)
This is new one one. It would seem to be an electronic failure of some sort Suggest you refer to Olympus Support on this one
Aug 20, 2007 | Olympus EVOLT E-500 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
26 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
