Question about Samsung S850 Digital Camera
In my digi camers memory card does not support at all..so what can i do??
How can I extract the pictures from the camera memory of my Canon 550D?
You can remove the SD memory card from the Canon camers and insert the SD memory card into an USB memory card reader. Connect the USB memory card reader into the USB port of the working computer. The computer will see this card reader as an external memory device, click on this device and open the folder that contains the photos and you can then copy the photos to your computer.
Jan 27, 2012 | Cameras
COOLPIX MEMORY CARD PROTECTION
If your memory card is a SD memory card then there is a small slide switch on the edge of the memory card. Remove the memory card from the camers ans move the slide switch from the Read position to the Write position.
Jan 22, 2012 | Cameras
I left my nikon D3100 outside with the tripod and i forgot to get it,then suddenly it got wet from the rain,what will i do?
Remove the battery imediately, the memory card and the lens. Place the camera body, lens and memory card in a warm dry and place for several days to dry out completely.
When the camers is dry, insert the battery, lens and memory card, turn on the camers and set the date and time.
If the camers does not work charge the battery and try again.
If it still does not work then you need to send it to the Nikon service centre for repair.
Jan 15, 2012 | Nikon D3100 Digital Camera
My nikon D3100 got wet from rain...what will i do?
No imAge
no image appear on the camer.,but you already taking pix??right??is the card inserted??if yes maybe your memory card was basted,try to insert another memory,,but wait.,before you insert the new memory card try to format the digital camera first.,
Feb 24, 2011 | Cameras
My PNY HCSD 8GB card wont read in any of the various photo printers ive tried it in but will read in cameras and computers. its not locked and the previously mentioned printers have no problem with any...
There could be many reasons for this problem..
1. The card is just too big - some readers can only cope with 2 or 4 Gb max.
2. The card's transfer rate may not be compatible - there are many differing speeds at which they can run and not all readers can cope with it.
Have you tried connecting the camer to the printer via USB? pic-bridge etc. will use the camer itself as a card reader avoiding compatability issues.
Hope this helps.
Jan 26, 2011 | PNY 8GB Secure Digital High Capacity...
MY DIGITAL CAMERE MEMORY IS FULL, WHEN I TURN ON MY CAMER IT SAID MEMORY IS FULL. I DON'T HAVE A CARD INSERTED IN BECAUSE WHEN I PUT THE CARD IN IT WON'T COME ON AT ALL. IT ONLY COMES ON WHEN I TAKE OUT OF...
camera's onboard memory is only 8MB, maybe 1 or 2 high resolution photo. delete the photo on the camera to clear error message and use only no more than 2 gig of sd card. It does not work with higher than 2 gig which is SDHC type sd card.
May 20, 2010 | Casio Exilim EX-Z55 Digital Camera
I scan my camers memory card it shows 62 viruses
How are you getting viruses on your card? Are you using your computer to add pics to the card? If so, that's the problem. You need to format the card in the camera.
Mar 03, 2010 | Canon PowerShot A75 Digital Camera
Problem with Memory Card door
I read some reviews for this camera, and other people are having problems with their battery compartment. It is a design flaw. If it is not under warranty, a repair might be around $200
Sep 15, 2008 | Olympus Camedia E-10 Digital Camera
How to transfer image from digi cams internal memory to my pc
Simply plug it into the PC. If the PC is an ME/2000/XP it should recognise the camers and put up the camera/scanner wizard. Come back tell us what you get, You do not need the software from the CD- if it is in- Take it out.
Sep 22, 2007 | Vivitar ViviCam 4100 Digital Camera
Samsung S850 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
