Question about Samsung SpinPoint P80 SP1604N 160 GB Hard Drive
What are the cylinder, Head & sector setting for Samsung SP 1604N
What are the cylinder, head and sector setting for a Sansumg SP 1604N hard drive. By Bois does not auto fill in these figures.
5 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: auto focus problem SAMSUNG SP-48T5HP
It needs to most likely be re-initilized in a technician service menu. If the convergence looks fine otherwise this is most likely the cause.
Posted on Mar 02, 2007
  • 33 Answers
SOURCE: connecting bluetooth head set
>Paraphrasing from the manual:
>1. Turn off headset.
>2. Press & hold the Multi-function button for 8 seconds, until >the lower half is lit up blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
>3. Set your 'phone to discover bluetooth devices.
>4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you want to pair with it. Confirm by pressing "Yes" or >"OK".
>5. Enter passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
Posted on Apr 05, 2009
  • 567 Answers
SOURCE: how to pair a motorola h17 head set to a samsung
try 0000 that is the universal code
Posted on Jul 05, 2010
fanaudi
  • 1381 Answers
SOURCE: I would like the Cylinder head and sector settings
Would' nt a surface test with partition Wizard be sufficient ? It did help me .
Best regards .
Posted on Jan 29, 2011
How much is the engine head of Mazda 3 1.6 2007 16 v
Mazda 3 Cylinder Head ' eBay
www.ebay.com/bhp/mazda-3-cylinder-head
eBayEngine Cylinder Head Bolt Set Fel-Pro ES 72207 (Fits: Mazda 3) ... 2.0l & 2.3l dohc l416v, w/ turbo, "duratec" 2004 - 2009 mazda 3 2.3l dohc l4 16v. 2007 - 2009 ... #O608 RIGHT CYLINDER HEAD 2007 MAZDA3 2.0 MANUAL 4683894AC.
Oct 29, 2015 | Mazda Cars & Trucks
Hitachi hdd head swap
Hard drives repairs is not a DIY job because they need to be opened in a clean room environment.
Apr 01, 2013 | Hitachi Deskstar T7K250 HDT722516DLA380...
Convert lba to cyl, head, sector
The problem with CYL/HEAD/SECTORS is that disk-drives have gotten *MUCH* too large -- the limited size of each field mean that a new scheme, namely LBA (Logical Block Addressing) had to be created to deal with disk-drives that are 1000 times too large (4 Terabytes versus old 4 Gigabytes).
So, if you have 312,500,000 sectors,
and each sector is 0.5 Kilobytes,
you have 156,250,000 Kbytes,
or 156,250 Mbytes,
or 156 Gigabytes.
Sep 06, 2012 | Western Digital WD1602ABKS 160GB 7200 RPM...
Describe your samsung sp0822n how to removing a bed sector in hard disk
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer hope this helps
May 07, 2011 | Samsung (SP0822N) 80 GB Hard Drive
What memory card should I use w/this hard drive? I have changed hard drives in this computer (HPa1010n) and want to put back the original hard drive and memory card but not sure which one came in this...
Check all the sequential numbers on everything. The lowest serial or mfg date, anything that will give you a clue as to which is the oldest, therefore original.
Dec 24, 2017 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
What numbers off the HD do I use to set up the CMOS on the mother board under "User" hard drive?
Use automatic detection if it is available; if not use the following:
Size: Usually set automatically depending on the settings for heads, sectors, and cylinders.
Cylinders: The number of cylinders on hard disk. Should be written on drive.
Heads: Number of heads. Should be written on drive.
Write precompensation: Not much used on modern drives. It was used to accomodate drives that had the same number of sectors per track, including both the inner and outer tracks. On SCSI drives
, set this to -1. On IDE drives, it is not necessary to worry about it as it will be determined automatically.
Landing zone: Used for drives that don’t have auto-parking. All modern drives do, so just set to 0.
Sector: Number of sectors per track. It’s often 17 for MFM drives, and 26 for RLL drives.
Jun 26, 2009 | IBM Computers & Internet
Paramet cyl = ? head=? sect = ? of QML30000LD-A
Written on the FireballPlus AS label it says
C/H/S: 16383/16/63 = 16514064
( averages out to 1817 bytes/sector )
LBA's: 58633344
( x 512bytes/Blk = 30,020,272,130Bytes )
Dec 06, 2008 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Samsung SpinPoint P80 SP1604N 160 GB Hard Drive Logo
379 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
