Question about Logitech Cordless Vantage Headset for Playstation 3
NEW PS3 IS NOT FINDING HEADSET - Logitech Cordless Vantage Headset for Playstation 3
  • 16 Answers
JaWay (solution #1) is wrong. The usb cable is solely meant for charging the headset.
I had a few issues of my own. The manual is **** so don't follow that.
You mention somehting about a new PS3, taking that you have paired it before with another. Turn on the headset and press the reset button with the tip of a pen for a few seconds. The headset should now be reset and turned off.
Go to settings > accessory settings > manage bluetooth devices, from here you should be able to register a new headset. Initiate the search on your PS3. Hold the middle button for 10+ seconds. Till the led starts to flash alternating red and green. The PS3 should now be able to pick it up.
Posted on Apr 20, 2010
    Problem Solver:
  • 7 Answers
Well, are u using the USB cable?
Posted on Oct 07, 2009
My ex-03 dont connect to my ps3
i use the ex03 also, try starting from the start. go to the headset connection setup on the xmb menu, and delete the ex03 from the list. then hold down the button on the headset till it stays a sold color(not flashing ). then on the ps3 you should see your headset click on it and then enter four zeros. you should now be able to connect . also, make sure the headset is selected in the device use settings .
Jul 27, 2012 | Sony Playstation 3 (PS3) Console
I have a mad catz mw2 8860 that was given to me how do i make it work with my system if it was being used with another? from the start i know nothing about this device
You have to pair it with your PS3 or another device through BlueTooth.
Pairing is a process of associating Bluetooth devices with each other. It will establish a permanent security link between the devices and enable quick access to the services provided without the need to re-enter Pass Keys. You will only need to pair your PS3 and the Headset once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Apr 06, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Installing mad catz ps3 bluetooth
In order to use it you have to pair it with the PS3.
Trouble Shooting
Feb 27, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Im trying to hook up my mad catz bluetooth to my ps3 and i got it pass the scan part but it keeps saying theres a problem...PLEASE HELP
Is your PS3 seeing the Headset?
Is the headset in pairing mode?
Complete details below on how to connect it:
Trouble Shooting
Feb 22, 2011 | Mad Catz Bluetooth Headset for PlayStation...
I cant find instructions to sync my Mad Catz PS3 Blu tooth headset
Hope it helps:
Trouble Shooting
Jan 30, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
I am unable to sync my Mad Catz bluetooth to my PS3 and I can't find my bluetooth manual. How do I sync up?
Please see the sync details below:
Trouble Shooting
Jan 28, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Recently when i try to connect the bluetooth to my ps3 it says that a connection could not be established.Howq do i fix this?
Aug 18, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do you get the ps3 to pick up the blue tooth head set
Before the Headset can be used with the PS3, the two devices must be ‘paired’ so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
2. Within the “Settings” menu, press X on “Accessory Settings.”
3. Press X on the icon labeled: “Manage Bluetooth® Devices.”
4. Scroll down and press X on the icon labeled: “Register New Device.”
6. Once the Headset’s LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on “Start Scanning.”
8. Locate “8860” from the list of available devices and press X on its icon to be prompted for a Pass Key
10. You should then be taken to a new screen stating: “Register completed”
Trouble Shooting
Source: www.madcatz.com/faq
Aug 11, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Logitech Cordless Vantage Headset  for Playstation 3 Logo
688 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
