Question about GE Ovens
My oven shuts down after half hour of use and it blinks the error f9
  • 6,784 Answers
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the wiring is correct, and the mechanism is not stuck, this will confirm that the door lock mechanism is faulty. Replace it asap.
Posted on Sep 29, 2009
Oven not working
F9 Door Latch Error Check latch and latch circuit
F9 Door Lock Warning Check door lock circuit or Replace Clock
F9 Program with door circuit Check wiring
4 different brands of stove indicate an issue with the door lock circuit. Hunt down the the tech manual for your machine on my youtube channel video
May 05, 2013 | Ovens
What does F9 mean
Failure to clean code
I have two Monogram ovens but they are not adjacent to each other top and bottom but are separate in different areas of the counter. I did the self clean for both ovens for the first time and one oven had the F9 error code about 1 hour and 45 min into the clean and the other did not sound a code.
Jan 24, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
When I try to set a temperature, F9 appears. I have tried to turn off power by flipping circuit breaker. The power was off and I set a temp, then turned it off and F9 appeared again with "lock." Any...
The most common cause of a F9 error code is a problem with the door latch circuit. There could be a pinched wire for the circuit causing a short or the door latch motor is defective. Sometimes a problem with the ERC can cause this error to appear. Possible problems can very slightly from manufacturer for this error code but almost all use the F9 error code for the oven door lock.
Jan 14, 2010 | Ovens
Frigidaire electric drop in oven has blinking door locked light on. F9 error message. Tried to self clean, oven never got hot, door locked and can't get open. Been 2 days. Self clean light will not come...
http://b2b.frigidaire.com/support/manuals.asp
this is a free download site from frigedaire if you have your model number you can download your complete manuel i was unable to find the F9 code for an oven
but suspect it has to do with door lock switchs if you can download your manuel from site it may help you can try shutting off breaker for oven and see if it will reset
good luck ron
Dec 11, 2009 | Ovens
My GE Oven JTP 14 displays an F9 error and shuts off.
F9 error - Lock switch error.
Resolution - Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Hope i helped you.
Thanks.
Sep 02, 2009 | GE Profile JTP18 Electric Single Oven
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Ovens Logo
159 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
