Question about Panasonic PT-AE900U Multimedia Projector
Even spaced vertical lines across the whole screen on all sources
I have vertical even spaced lines across the whole screen. i went into the service menu to check the colors in flicker adjust on the blue and the red screens there are no lines but on the green screen the lines are there any suggestions?
  • 5 more comments
  • spudz Feb 08, 2008
    I have the same projector PT-AE900U and the same problem , looks like you are watching tv through a screen as the horizantal lines are there too just less visable . I have eliminated the bulb by trying a working one with much less hours ... still have the lines . I am thinking a prob with the lense or lcd component . hope there is a tweak for this as mine is off waranty :>(
  • spudz Feb 11, 2008
    Well I have brought my AE900U into the shop today , will post the diagnosis and repair costs when i get them , they said it could take 2-3 weeks :>(
  • bobbobr Jul 11, 2008
    I have the same vertical line problem with my PT-AE900U. The rattle fan sound has gone away and now I have this problem. Bummer.
  • LukeU Jul 12, 2008
    I have the same problem.... anyone get an idea on a fix yet?
  • allanes5 Jul 23, 2008
    I also have the even spaced vertical lines runing up on the screen with DVD or cable input but not with the blue Panasonic screen.
  • Anonymous Mar 18, 2009
    I have to tell you. I took apart my PT-AE900U a while back because I was having this same problem and reconnected everything but that didn't fix it so I went back and followed Gorkish's advice. I removed the 2 heat dissipators, cleaned out the areas around the ICs inspecting for any solder shorts and reconnected everything. I was AMAZED when it worked perfectly after that. I then went back in and installed a large piece of flat aluminum connecting the 2 heat dissipators to prevent future overheating. When I was between homes and living in an apartment for 9 months I was forced to mount the projector in close proximity to all the other equip (cable box, reciever, PS3, VCR) which I am sure led to the overheating and vertical line problem. Thanks much Gorkish for saving me.
  • rmille38 Mar 18, 2009
    Thanks Gorkish!
    Your procedure actually worked for me and my PT-AE900U is back in service again and operating flawlessly.
If you are handy with SMT rework it might be possible to fix this problem. The heat spreaders on the LCD drivers are insufficient to cool the chips and they will get hot enough to reflow the solder and cause a short on some of the pins. I think it most often happens after bulb replacement since bulbs near their end of life are dimmed and run cooler. After replacing the bulb the bit of extra heat is all that is needed to push them over the edge.
The problem also seems to be most prevalent on the green IC since it shares a heatsink with red and has a smaller area to dissapate the heat into.
If you pull the heatsink you will probably be able to see the short with careful inspection. The pitch is very small - 0.6mm but I was able to wick, clean, and reflow one side of my green IC and the problem went away.
I am planning on adding some additional aluminum stock to the heat spreaders with some thermal adhesive to give the chips more cooling.
By the way the very common rattle noise in these projectors is not a fan but the auto iris. You can unplug the iris servo from the mainboard and disable the auto iris in the menu to work around the problem or you can replace the iris servo for about $75, again, if you are handy with that sort of thing.
Posted on Dec 30, 2008
  • 1 more comment
  • John Laur Nov 18, 2010
    Thanks everyone for your success stories; happy to help. BTW my projector is still going strong!
  • JimF Mar 31, 2013
    Gorkish- it's been about 20 years since I was mucking around on my old amigas circuit board. So forgive me i am a bit rusty. Where are the heat sinks you refer to specifically? I'll try to attach a pic. JimF
  • John Laur Mar 31, 2013
    There is a photo posted in the 3rd comment here that shows the heat spreaders. There are 3 large ICs that drive the lcds one each for R G &B. you can see the ribbon connectors going down into the projector near them.http://www.avsforum.com/t/1422733/help-w...
Vertical black bars screen
Try connecting an external monitor to the 15 VGA (video) plug on the laptop and see if it displays properly on the monitor. You may have to direct the video from the laptop to the monitor by holding down the blue <FN> (key next to the space bar) and then press down the <F8> key.
If the display on the external monitor is correct, then you either have a problem with the laptop's LED display screen or cable that connects the LED to system board. Here is a link for the service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-9300_service%20manual_en-us.pdf
Feb 16, 2013 | Dell Inspiron 9100 Notebook
Vertical Lines
Hi I can try soling your problems
Feb 22, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Wobbly lines on my Toshiba TW56X81
This sounds like a input problem. The source of the signal may not be well matched to the expected input spec. To test, see if the "SETUP" menu items are clear. If so it is something to do with a cable, connector, or configuration of the source.
Mar 12, 2008 | Toshiba TW56X81 56" Rear Projection...
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
Panasonic PT-AE900U Multimedia Projector Logo
2,731 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
