Question about Kenmore Washing Machines
Kenmore stackable model number 417.92702200. Smell of burnt rubber and stops during spin cycle of washing machine. Is this an easy fix?
  • 39 Answers
SOURCE: very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Posted on Sep 16, 2008
Healeyman
  • 1198 Answers
SOURCE: washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
Posted on May 04, 2009
JULIANFIX
  • 975 Answers
SOURCE: Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
Posted on May 18, 2009
  • 1937 Answers
SOURCE: My washing machine (Kenmore 70 Series) does not spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Jan 12, 2010
SOURCE: Burnt rubber smell after replacing motor coupling
what has happened is that the coupler has not been fully seated on the gearbox shaft, the motor shaft, or both. you should use a socket and hammer to firmly seat the plastic coupling on each shaft. If the coupling is not properly seated, the washer will work, you will get rotation, but there will be constant back pressure on the motor shaft, pushing it against the rear bearing race and the pump at the rear, the added friction causes heat buildup in the motor and sometimes overtemp switch operation. Just solved this tricky problem myself. another clue that the coupler isn't fully flush and seated is the last motor retention strap is very difficult to get on, due to the 1/8-1/4 inch extra length.
Posted on Apr 13, 2010
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
Kenmore 22622 washer tub will not spin during spin cycle, burnt smell
Sounds like the belt between the motor and the tub is slipping or the tensioner spring may have failed.
Dec 14, 2013 | Kenmore 22422 Top Load Washer
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
MACHINE STOPPED - BURNING SMELL COMING FROM WASHER
The burning smell is from your coupling and when this breaks the rubber spins across the plastic face of the opposite coupling. Your washer will not wash or spin until this is replaced. fortunately these are cheap and easy to replace. Refer to my step by step instructions to replace yours.
Here is the guide:
http://www.fixya.com/support/r4355933-washing_machine_repair_direct_drive
Mar 24, 2010 | Washing Machines
During the spin cycle it started making a whining
it must be motor run away condition. motor must have exceeded its design speed and the internal windings must have parted off. you did the right thing. but, when your son switched on again, it would have run for few minutes with all internal extra friction and stopped with burnt smell. you have lost the motor. but, before replacing the motor get the speed control system checked.
Mar 19, 2010 | Maytag Performa LAT2500A
Wont spin cycle at full speed
Burning smell is a slipping belt. These are tricky to get apart and diagnose but find the reason the belt is slipping and replacing it will solve your problem. Could be clutch, bearing or gearcase related.
Eric
Dec 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
May 18, 2009 | Maytag Dependable Care LAT9416
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing machine broken, kenmore model 110.92274100
REPLACE THE DIRECT DRIVE COUPLING IT IS BETWEEN THE TRANSMISSION AND THE MOTOR PART NUMBER IS 285753A THE TRANSMISSION IS NOT BAD
Apr 22, 2008 | Washing Machines
Washing Machines Logo
233 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
