Question about Juki TL-98Q
Juki TL98Q needle thread breakage
My machine is doing the same thing. It is sewing along fine and suddenly the needle thread breaks when the needle is in the down position. I have changed the needle, checked all tensions, cleaned everything, re-threaded, with no change.
  • 59 Answers
Your bobbin it is not in his right position, quit tightin your tension.
Posted on Mar 26, 2010
Use a thread stand and rethread.
Posted on May 23, 2010
Why does my machine break the thread a lot? A juki cp 130
tension too tight or incorrect threading, or bad thread.
Mar 13, 2017 | Juki Sewing Machines
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
Thread keeps breaking using husqvarna
try these suggestions
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Oct 30, 2012 | Husqvarna Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Oct 08, 2012 | Juki Sewing Machines
I have a Juki DDL 227. Top thread keeps breaking instantly
Well, you've not checked "Everything" but you have checked the common things.
Do you have any idea of where it is actually breaking? Re-thread your machine and see if you can determine exactly where the break occurs.
Sometimes a damaged needle throat plate will break threads... as will a burr on the hook in the bobbin area. Also if there is a burr or rough spot on the thread spool it will sometimes catch and cause breakage.
Good luck
Jul 23, 2012 | Juki Sewing Machines
Changing needle on juki tl98q
Push needle all the way up into needle bar shaft, flat side toward back. Firmly tighten screw to secure needle. Jimmy
Apr 09, 2012 | Juki TL-98Q
Thread breakage on Juki TL-2000Qi
There are a few reasons the top thread may break.
- Check the needle plate for damage around the needle hole. Polish any burrs with fine sand paper or a needle file.
Check the hook for damage. If the hook is damaged it can cause the thread to break as it comes off the tip. Be very careful if you must remove burrs from the hook. Changing the shape of the hook tip will cause skipping problems.
Check that the top tension is not too high. The top tension should be set at a medium number
Burrs on the needle plate
Burrs on the hook assembly
Bobbin tension is too tight
Jan 16, 2012 | Sewing Machines
I have a juki tl98q sewing machine for my mid arm. The bottom thread keeps bunching up and I cannot sew anymore. What can I do to fix this? Do you have a diagram to thread the bottom bobbin and the top of...
The threading diagrams are available in the manual which is available from Juki on the TL-98Q product page: http://www.juki.co.jp/household_en/pism/tl98q.html . The direct link to the manual is http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf . See pages 14-18 (pages 16-21 of the PDF).
There are a couple of things I recommend that you check. First, make sure that the bobbin is evenly wound. This is a function of the bobbin winder tension; see the manual (page 15) for that adjustment. Next, check if the bobbin case tension is correct. Place the bobbin in the bobbin case and dangle the unit from the thread. Try to shake the bobbin case up and down, sort of like a yo-yo. The thread should advance by a bit. If the thread length doesn't change, loosen the set screw on the side of the bobbin case a small amount. If you get a really long tail of thread, tighten the set screw. See page 21 of the manual.
Next check for any loose threads and dirt in the housing around the bobbin case. Depending on the length of time that you have been using the needle, replace the needle.
I hope this helps.
Sep 28, 2017 | Juki TL-98Q
Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Jan 18, 2009 | Juki TL-98Q
Juki TL-98Q Logo
347 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
