Question about Brother IntelliFAX 4100e All-In-One Laser Printer
All faxes are not received when scanning 37 pages.
I scanned a 39 page fax and only 18 goes through. How can you tell the number of faxes the went through?
  • 615 Answers
I am attaching a copy of the manual that tells you everything and how to set them up.
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000400/ALLFAX_UsaEng_PrinterUG.pdf
Posted on Sep 29, 2009
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
I using a roller fax machine. today i had fax a documents that have 4 pages and i put together and let it run auto. i confirmed that i fax once only but the receiver received the first page more than 10...
By "roller fax" if you mean auto document feeder, so what's the problem? If you didn't see each of the 4 pages feed into the machine one at a time then what happened at the other end could be because something happened at your end. It's the reason we scan and email most critical documents today.
Carl
I am using a printer of brother mfc and i can not understand how to fax from it
The default setting on Brother MFC printer is Fax. Meaning you will usually see the Fax Button lit with a green light. (If the fax button is not lit, just press that button to get it lit.). Put the sheet of paper you want faxed with the side you want sent face down. Now press the OK button. The screen will ask you to enter the Fax number. Key in the Fax number. Press start. The printer will start scanning that page. Once the first page is scanned it will give you 2 options. You can press 1, if you have more pages to send to the same Fax number. or you can press 2. This will tell the printer(Fax) it is just a 1 page document and the machine starts dialing. Wait for the fax completed message. Please make sure that the machine is connected to a working phone line before you start.
Aug 13, 2010 | Computers & Internet
I have an all in one and I can print, scan, and
On the printer press setup-->choose tools option-->under tools-->choose print a fax test page.
Find out how is the printer connected with the fax line.
Note:- Line 1 at the back of the printer should be connected directly to the wall jack of phone line.
Now Follow the instrcution below.
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, They will generate a return fax to you within five minutes confirming that they have received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Note:-The most common cause of failure is that the fax number set in the Fax Header on the machine does not match the number of the phone line connected to the fax. Also, ensure that the fax header contains the full 10-digit telephone number of the fax machine, including the area code.
May 10, 2010 | HP Officejet 4215v All-in-One Printer
I need to know how to send a fax from a brother MFC-295cn all-in-one printer
Hello Frank,
Sending a fax is fairly simple.
1. Make sure you have a telephone line connecting to the LINE jack on the side of the MFC-295CN
2. Check if you have a dial tone by pressing the "hook" button on the machine while the line is free.
3. Place a page face down on the flatbed scanner or in the document feeder on the top of the machine.
*Note: If you are using the document feeder, once the page is placed in, you should see "enter fax #" on the LCD
4. Enter the fax number the same way you would dial a regular phone number.
5. Press "Start"
*Note: If you are using the flatbed option, after the sheet is scanned, you will be asked if you want to scan a second page. For additionnal pages, press 1, to end scanning and start faxing, press 2
6. If the fax goes through properly you will see "completed" on the LCD
Mar 25, 2010 | Office Equipment & Supplies
NUMBER OF FAXES THAT IS GOING THROUGH
This might be a limitation on the receiving side - some faxes have such limitations as a poor man's "anti-spam" measure...
Sep 29, 2009 | Brother IntelliFax-4100e Fax
HP 1020 fax
From manual: Insert document; press Scan & Fax button; dial number; press Start/Copy.  All pages will be scanned, number will be dialed, and scan will be transmitted.  If Memory Full displays, repeat procedure without using Scan & Fax button.
Jul 15, 2008 | HP 1020 Plain Paper Thermal transfer Fax
Brother IntelliFAX 4100e All-In-One Laser Printer Logo
35 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
