Question about HP Photosmart A618 InkJet Printer
"Cartridge failed, Please Replace it"
I am Getting "Cartridge failed, Please Replace it" ehile starting up mu HP Photosmart A618. It was working Just fine and the cartridge was almost new and Full.
ctf1800
  • 4402 Answers
SOURCE: cartridge failed after replacing it wtwice
unplug and plug back in?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035736&cc=us&lc=en&dlc=en&product=305375&dlc=en&lang=en
are you sure you have the correct one in the correct slot?
Posted on Dec 21, 2007
SOURCE: HP Photosmart C5180 will not read new ink cartridge
Same problem with the yellow cartridge, tried pulling power cable out and removed all cartridges then power on and reinstalled carts.
No change. On the way to take it back to the retailer I dropped by Cartridge World and by off chance asked about the printer, they ended up weighing the cartridges and discovered my new cart had no ink in it. A new cart fixed the problem much to my relief.
Posted on Mar 28, 2008
I just purchased new hp cartidges and I still get error massage cartidge #57 needs to be replaced.
The line on the printing at the end or far right of the sentence (like the last 3 or 4 words are faded)
this is for hp 7550 photosmart
Posted on Oct 29, 2008
chiploon
  • 32 Answers
With reference to Expert Burti, he has given the solution to your problem.
"Just got off the phone to HP and the issue is resolved *phew*. This waswhat I was told to do for my C5180. First they told me to do a powerdrain. This is done by pulling out the power cable and then holding theon/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it. :
Have to say it looked like this whole process used up shed loads ofink, so by the time I had finished I needed to replace 3 cartridges!
HP were pretty good and were very willing to send out a new printer if the reset didn't work (as the printer is still in warrenty). Hope you get yours sorted too."
With thanks from expert Burti.
Posted on Jan 02, 2009
  • 23 Answers
SOURCE: How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Posted on Feb 17, 2009
My HP Photosmart C4400 keeps giving me the message, "The cartridge cradle cannot move. Please turn device power off. Check device for a paper jam or other obstruction." Two days ago, early in...
sure
or paper scraps in side blocking key sensors or other parts
clean all that chaff out first.
blow it and brush and pluck it all out.
there is nothing simple on printers, and 10000 types.
if fails to work after all that , it needs service.
Mar 16, 2017 | HP Photosmart C4400 series
Incompatable Ink Cartridge HP C4480
Cartridge failed try another new one.
Yea it is new and should be good but they are machines and are prone to failure too.
Jul 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart 335 - cartridge failure
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | HP Photosmart 335 InkJet Printer
Photosmart error code.
Andy,
You are in the free section of FIXYA. We volunteer our time and experience and don't get paid, this not the HP Company.
Anyway, ink catridges are how HP makes their money, they couldn't care less about the printers.
There's no away around the bad cartridge problem.
Dec 28, 2008 | HP Photosmart A618 InkJet Printer
HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Aug 03, 2008 | HP Photosmart D7360 All-In-One InkJet...
Cartridge 57 failed
Brenda Walker on August 18, 2009
I think I may have solved this problem. What I did was take out the #56 cartridge and hit the print button. It started to calibrate and then said it was printing on reserve or something? Yup, it printed with only one (#57 cartridge). After that, I stuck in a new #56 cartridge and so far so good for it only happened yesterday.
I hope this solves your cartridge #57 failed problem. Let me know if it does.
Aloha from Hawaii
May 01, 2008 | HP PhotoSmart 7660 InkJet Printer
Cartridge failed after replacing it wtwice
Dec 21, 2007 | HP PhotoSmart 7760 InkJet Printer
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
HP Photosmart A618 InkJet Printer Logo
152 people viewed this question
Ben Johnson
