Question about Pioneer DEH-1600 CD Player
Deh-1600 which wire in the harrness will supply my power antenna with enough juice to make it open all the way.If there is not a wire with enough power where can i draw from
  • Pioneer Master
  • 3,289 Answers
The radio's blue wire is a 12 volt output designed for a power antenna.
If the antenna is struggling to extend fully, it may need to be cleaned and lubricated with a dry lubricant - such as silicone. Do not use oils, as they attract dirt and dust very quickly.
Posted on Sep 29, 2009
    Genius:
  • Pioneer Master
  • 1,550 Answers
It is the blue light color
What are will hook up to my power antenna
there are 2 wires you can try, the blue wire or blue with white, 1 will give a constant 12volts when the radio is turned on the other will give 12 volts for 15sec the go to 0 volts
Apr 25, 2010 | Pioneer DEH-1600 CD Player
I need the color cordination for a pioneer DEH-1600
Yellow + 12 VDC constant
Red + 12 VDC switched (ACC)
Black - Ground ( car body/frame )
Blue/White Power antenna or remote Amplifyier
White + Left Front
White/Black - Left Front
Gray + Right Front
Gray/Black - Right Front
Green + Left Rear
Green/Black - Left Rear
Violet + Right Rear
Violet/Black - Right Rear
Jan 27, 2010 | Pioneer DEH-1600 CD Player
Pioneer deh-1600 wiring diagram
YELLOW--constant 12 volts
RED--connect to 12 volts controlled by ignition switch
ORANGE/WHITE--lighting switch for auto dimming
BLACK--good chassis ground
BLUE/WHITE--amp turn on signal or power antenna
YELLOW/BLACK--auto mute lead
WHITE--frt.left speaker-positive+
WHITE/BLACK--frt.left speaker-negative-
GREEN-rear left speaker-positive+
GREEN/BLACK-rear left speaker-negative-
GRAY-frt right speaker-positive+
GRAY/BLACK-frt right speaker-negative-
VIOLET-rear right speaker-positive+
VIOLET/BLACK-rear right speaker-negative-
Jan 06, 2010 | Pioneer DEH-1600 CD Player
What wires go where on a pioneer deh 1600
Need what year, make, and model your vehicle is, but the yellow is positive constant
red is positive Acc.
black is ground
orange is illuminator
blue is if you have power antenna
white and grey are front speakers
green and purple are back.
email me with your info so I can tell you where they go in your vehicle.
xxsodasipperxx@yahoo.com
Nov 27, 2009 | Pioneer DEH-1600 CD Player
Whats the color code for deh-780mp wiring harrness
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Sep 20, 2009 | Car Audio & Video
Looking for wiring colors location
red -Acc power
black -ground
SPEAKERS
white left front +
grey right front +
green left rear +
purple right rear +
Aug 28, 2009 | Pioneer DEH-1600 CD Player
I have a deh p3900mp
Antenna does act as ground, just not the best way to do it. Use the 6mm bolt hole in the rear of the chassis for a mounting strap, run a wire from there to the factory (vehicle) radio harness ground.
May 17, 2009 | Pioneer DEH-P3900MP CD Player
Trying to install pioneer cd player in street rod.
You need:
a 12v + source from the battery (yellow wire)
a 12v + switched with the key (red wire)
a Ground (black wire)
then you need your four speakers hooked up, i'm unsure of the color codes on them but they are usually pairs i.e. green and green with black stripe for one speaker white with black stripe for another etc.
other wires such as illumination (orange) and power antenna (blue) are optional
the illumination (orange) you would connect to 12v + from a headlight switch and it would cause the unit to dim when you turned your headlights on
The power antenna (blue) is used, as the name implies to control a power antenna if you have one, or more commonly as the signal to turn an audio amp on (on the remote connection)
Hope this helps
Feb 15, 2009 | Pioneer DEH-1600 CD Player
Pioneer deh-1600
i know theres many of people out in this world using google or what ever and need this so here it is for pioneer DEH-1600
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Aug 26, 2007 | Pioneer DEH-1600 CD Player
Pioneer DEH-1600 CD Player Logo
168 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
