Question about Frigidaire Washing Machines
How hard is it to replace the motor on a frigidaire FWT647ghs1 front loader?
duby1990
  • 367 Answers
SOURCE: I have a Frigidaire Gallery
It can be be your speed control unit. It also can be your door switch. Even though it locks there is still another switch inside that sometimes fails. That is your cheapest way to start and a lot of times that fixes it. If not replace the speed control unit.
Posted on Nov 18, 2008
beltronic205
  • 1466 Answers
SOURCE: Belt will not stay on the drum when we spin it.
check your drum pulley is this warped or slack,
Posted on Apr 16, 2010
caroldon
  • 17130 Answers
SOURCE: I have a fridgidaire washer
Seems your timer is faulty for sure as it is not lcoking on to the contacts in th set program.
The intital cycle seems to work as the water loads into the drum but then the next section of the motor drive is not intitiated. Please check also the water level control, the pressure swtich that needs to contact so as the timer goes on to the spin cycle with the motor working. So once the water level is reached does it stop? if so the timer is a suspect as the pressure switch cuts off the inlet valves but if not the pressure swtich must be checked.
Other wise the timer controller unit is a prime suspect.
Posted on Nov 05, 2010
tunde007
  • 2382 Answers
SOURCE: I have a Frigidaire Gallery Series front load
If the machine doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
If the machine pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
dr appliance
  • 266 Answers
SOURCE: My frigidaire Gallery Washer spins
frigidaire washers have a coin trap connected bottom of tub 3'inch hose to !'inch1/2 drain pump soft black rubber hose clean and retest
Posted on Jan 27, 2011
Is there a recall on Frigidaire front load washers. i have had mine for less than 5 years and motor is coroded. Very disappointed. especially for the cost. Debbie Richardson 706 8886362
You need to contact Frigidaire customer service for this, they will have all that information. I don't know of any recalls on any front loaders personally, but based on my experiences with them they are to be avoided, more trouble than they are worth and the are problem plagued compared to top loaders (my 2 top loaders have lasted about 20 years each). And then there is the cost to buy versus a top loader.
Nov 04, 2016 | Frigidaire Washing Machines
Where is the motor coupler located on a Frigidaire washer front loader model no. gitr 1670 aso? year 2003.
Hello friend, thank you for your post!
I understand that you are searching for the location of the motor coupler on your Frigidaire washer, GLTR1670AS0. I was able to locate the parts manual and it does not show a part labeled motor coupler. I have attached the link for you to access the parts manual for further assistance. I hope this is helpful. -Matt
Frigidaire Manual Search Results
Oct 08, 2014 | Frigidaire Washing Machines
Code 62 on frigidaire front loader washer
Disconnect the plug from the drive motor and measure the resistance of pins 4 and 5 in the motor. If reading is between 105 and 130 ohms, replace the Speed Control Board. If the meter reads outside 105 and 130 ohms, replace the motor.
Sep 02, 2012 | Frigidaire GLTF2940ES Front Load Washer
Front loader won't spin, but it washes fine, drains fine
CHECK THE MOTOR. IF MOTOR GOOD, REPLACE MOTOR CONTROL BOARD.
BOYNISMO@YAHOO.COM OR 714-334-1998
Nov 27, 2009 | Frigidaire Washing Machines
My front loader, model #FTF30ES1 won't spin out
This could be due to water discharge. Clean filter/ pump if needd be could also be slow motor speed , worn belt/ brushes in motor. good luck
Nov 13, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a front loader frigidaire, belt is fine. I remove the belt and tried to spin the motor by turning to spin mode i just heard clicking but the motor did not spin. Is the motor bad?
The motor probably needs to be replaced. If you take the motor to a local appliance parts store they may be able to test it to make sure. Also they should be able to order you a new one
Jul 10, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire Gallery Series front load washer, model #FWT647GHS1. The problem is the washer will not spin on the rinse cycle. I can hear the drain pump working. the door is properly locked and the...
Nov 17, 2008 | Frigidaire Washing Machines
Washing Machines Logo
76 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
