Question about Samsung Lands Phones
My phone just started turning off a few seconds after I turned it on. the at&t store looked at it and said there was a place in the battery compartment that was red instead of white...meaning it had gotten wet or something shorted out the phone. The phone didn't get wet...does this sound like BS? What else could it be?
    Problem Solver:
  • 15 Answers
Definetly not BS....That is a water mark sticker inside the phone. It does need a reasonable amount of moisture exposed to it for it to change since it is generally located underneath the battery. I used to sell phones for Alltel and AT&T so that is how I know. That is also something that would not be covered under a company warranty since the warranty only covers phone hardware and software malfunction. If you had phone insurance then this would be a good time to use it.
Posted on Sep 29, 2009
Will not power up
Hi, Please remove the Battery from the cameraand give a look inside the battery compartment. Use a spot light & makesure that place are clean , the battery connector pin are not bend , broken orrusted. After that insert the fully charged battery and try to turn on. If itsnot turn on then its confirm the camera internal power supply unit is faulty.For few reasons this problem started.1. Theconnectivity cable from camera to Circuit board damaged or disconnected.2. Thepower supply transformer stops working & need to replacement.3. turnon button connection may disconnected.For the confirmation all you need to visit a camera repair store. Withoutvisual survey technician can't confirm you which one of them is faulty. Thankyou
Aug 04, 2012 | Vivitar ViviCam 8025 Digital Camera
My brand new camera will not turn on. Help?
Pleaseremove the Battery from the camera and give a look inside the batterycompartment. Use a spot light & make sure that place are clean, not rusted& the battery connector pin are not bend or broken. Use dry clean cotton orsoft cloth for cleaning the connector part. After that insert the fully chargedbattery and try to turn on. If its not turn on then its confirm the camerainternal power supply unit is faulty. For few reason this problem started.1. Theconnectivity cable from camera to Circuit board damaged or disconnected.OR2. Thepower supply transformer stop working & need to replacement.OR3. turnon button connection may disconnected.
After visual checking by the technician is possible to say which part isfaulty.
For the confirmation you need to visit a camera repair store. Withoutvisual survey technician can't confirm you which one of them is faulty. As you said its your brand new camera so best solution is ask for replacement for the camera. Thankyou.
Jan 03, 2012 | Kodak EasyShare CX7330 Digital Camera
My nikon coolpix 5700 will not turn on, i have bought new battery for it and it just won't turn on. what do i do?
Pleaseremove the Battery from the camera and give a look inside the batterycompartment. Use a spot light & make sure that place are clean , not rusted& the battery connector pin are not bend or broken. After that insert thefully charged battery and try to turn on. If its not turn on then its confirmthe camera internal power supply unit is faulty. For few reason this problemstarted.1. Theconnectivity cable from camera to Circuit board damaged or disconnected.OR2. Thepower supply transformer stop working & need to replacement.OR3. turnon button connection may disconnected.
For the confirmation you need to visit a camera repair store. With outvisual survey technician can't confirm you which one of them is faulty. Thankyou.
Dec 04, 2011 | Nikon Coolpix 5700 Digital Camera
My battery is constatly low. the battery can last for a few hours and then phone turns off. i tryed to buy a new one, but it seems to be even worst.
Hello
Is your phone charging, if it is charging, no problem.
The problem with your phone could be virus problem because virus runs battery down.
The second place to look at is the battery terminal of your phone, It is possible that the battery terminals are corrode, If the are, it will definitely keep running the battery down.
Look at these two areas with care and your problem could be solved.
Take care.
Apr 19, 2010 | Samsung SGH-D600 Cellular Phone
My Pantech Impact just keeps turning on and off, not responsive. Any idea how to fix it or force a reset? It doesn't allow access to the menu as it just keeps turning on and off. Any ideas? Thanks!
First thing to do is remove the battery for a few seconds and then replace it. While the battery is out of the phone check for liquid damage on the battery and on the back of the phone. There should be a little white round (sometimes square) sticker on both your battery (usually where the metal contacts are) and the back of the phone. If either of those is pink or red you have liquid damage to the phone but if you don't see any of that, replace battery, turn phone back on and see what happens. Are you getting the same response, any differences in the screen, etc? If so, it looks like a manufacture defect to me and I would suggest contacting your wireless provider either directly (store) or over the dreaded customer service lines we all loathe!! Good luck to you~~
Mar 29, 2010 | Cell Phones
Turned the key to start '99 Dodge Ram 1500, after 1 second of turning over, hand slipped & key turned off. Immediately turned key again to start, now the buzz sound of the fuel pump is lower in volume,...
Hello
The 1st thing to do is make sure the battery is not defective and that the battery post and cables are clean and free of corrosion and making a good connection, even if they seem ok clean them with a battery post and cable eyelet cleaning tool, they are available from any auto parts store for around $4.00, while u are there bring the battery with u and have it tested it is free at any of the many so called discount auto parts stores , these new sealed battery types can go just like that, one moment they crank the engine fine the next not, very common, have seen it dozens of times.
Dec 03, 2009 | 1999 Dodge Ram
Phone keeps resetting
this is a usual problem for this model.& no one cant repair it completly.u can flash your phone(putting new firmware in it) with new version & dont pick up batteris after flashing.bcz this problem will come back again
Oct 09, 2009 | Sony Ericsson Walkman W980i Cellular Phone
My P38 Range Rover wont start
Hi Adam,
Bring your vehicle to an auto parts or battery store. Ask if they could perform a 'Load Check' on your battery. This not only checks the voltage, but also the amps, as if it were under the load of turning your engine.
It takes a few seconds and the results are pass or fail. Fail means it's time for a new battery. Pass means we need to look elsewhere.
Comment back the results.
Hope you find this to be very helpful
Mike
Sep 21, 2009 | Land Rover Cars & Trucks
Problems with phone
it seems like that.but it can be solved.go to the samsung care & ask to restore the phone and update its software.
Dec 24, 2008 | Samsung SGH-J600 Cellular Phone
Freezing screen
remove the battery for few minute if it still dont work look in the manuel how to reset normally they put it in the back small push it with a pen hope it work cheers
Jan 18, 2008 | Samsung SGH-d807 Cellular Phone
Lands Phones Logo
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
